![]() | Home > Technical (L322) > Touchscreen frozen |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Dont jump start a FFRR! Sorry, but its a fact... Probably an ECU gone pop!
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
Thanks Craig, just had a look in the back and found some signs of condensation in the plug on the nokia phone unit. We are going to check the rest of it out. Will let you know. gone fishin' |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
Sounds like a faulty Bluetooth unit to me |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
Cam-Tech-Craig, why do you say don't jump start a FFRR? The reason I ask is because instructions on how to are given in my handbook and your contradiction confuses me as to what I should do if the need arises. |
Brian GOG Member Since: 08 Dec 2011 Location: leeds Posts: 57 ![]() ![]() ![]() |
Hopefully its not an ECU but I would reitarate Cam - Tech Craig and try not to jump start this vehicles wherever possible. In my experience with the locked screen its usually been down to a break in the MOST fibre optic circuit. The bluetooth module is normally the first point of car. If you don't use the bluetooth or just want to elimate it you can buy MOST prisims from LR dealers for about a tenner. It just plugs into the fibre optic circuit in place of the module. If you have removed the faulty part the screen and other controls should return to normal operation.
Pet monkey Member Since: 27 Aug 2012 Location: Cwmbran Posts: 1 ![]() ![]() ![]() |
Hi, thanks for your reply, I am having difficulty finding the MOST prism that you mention, I have contacted a few suppliers and no one knows anything about it. |
Hi pet monkey I found a bloke near by that might be able to help you,
Part no you need is LR019014
Thanks Brian |
