![]() | Home > Technical (L322) > front suspension higher than rears |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
I levelled mine out, and then dropped it 25mm. Looks a lot better and handles well |
was that just in standard mode,it does seems a lot.. ... - .- -.
Yeah, I'm hoping that the IIDTool only tricks the ECU for the mode you're in at the time and not all modes. If it went into "motorway" mode when I'm in Germany later this year I'd be worried about a 5mm-lower-than-access-mode height at 100+ mph |
i think that you might have inadvertently lowered the whole lot..have a check in access to see if thats come down 25mm as well, if so then you can bet the motorway mode has as well.. ... - .- -.
Well as long as I remember to change it when I go abroad I should be ok then. I keep the IIDTool in the glovebox in case I get a temptation to nip off-road anyway. |
thats the beauty of this tool, so small and easy to use where ever you are.. ... - .- -.
