Home > Maintenance & Mods (L322) > Damped opening of lower tailgate
Page 7 of 12 <123 ... 678 ... 101112>
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Ordered from Dan a fortnight ago and fitted - excellent upgrade Very Happy
Whilst I had the tailgate down I removed the carpet and put lots of lovely Waxoyl inside the tailgate - no rust there - but just to make sure for future Wink
Also when I removed the old tailgate strap it was very very rusty so as mentioned in a previous thread - check and replace asap Shocked
Post #134342 4th Aug 2012 4:21pm
Astron21
Russia 2007 Range Rover Supercharged Supercharged Java Black
T24RES wrote:
I fitted mine yesterday as above, i quickly found that the bolts weren't that secure. Put nuts on the back, that wasn't a two minute job Big Cry However all in all a good mod with a dampened tail Thumbs Up
Could you please explain in a detail how you've fitted the nuts on the back?
I have removed the caret cover but still no idea how to push it inside because it's all covered with metal...
Post #137772 25th Aug 2012 3:08pm
Aurrian
2005 Range Rover Vogue SE Td6 Java Black
I also found that the self tapping nuts were not secure, and looked difficult to get in to put nuts behind so I used "rivnuts" as suggested by someone earlier on;
rivnut tool
Got cheap steel M6 rivnuts from ebay.
Really easy to fit an very secure. Very Happy
I would still be interested to know how you get access to the rear of the panel though...
Post #137792 25th Aug 2012 6:41pm
Astron21
Finally have expanded/drilled the technological hole under the carpet cover near the bracket and installed the nuts through it
Post #137842 26th Aug 2012 4:16pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
Did you drill a third hole? If so where and what size? Cheers
Post #137872 26th Aug 2012 9:24pm
Astron21
There is already a hole around 1cm diameter ~10 cm away from the bracket installation place, I have only expanded it to 4 cm in diameter
Post #137892 27th Aug 2012 5:53am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Just did this nice upgrade, ordered the parts from brit-car.co.uk (including the two screws), drilled two 5mm holes and then used a 6mm plug tap for the threads. All OK! The second photo from the first page was very helpful!
Post #184881 26th Apr 2013 11:59am
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
lovely bit of kit
bought from Dan @ duckworths - even though price has gone up he was still cheaper that others
fitted in half an hour works a treat Razz
Post #199349 18th Jul 2013 8:31am
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Very satisfying, if a little sad according to the family.
Old straps badly corroded, so did the upgrade at same time as replacing the straps. Very easy and used rivnuts as suggested in a previous post. The is an elegant solution and mote satisfying than self tappers. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #213010 29th Sep 2013 11:36am
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
have done this upgrade today - what a difference that shock absorber makes - open much better and in line with what one would expect of such a luxury vehicle
Post #252743 4th Apr 2014 6:35pm
miggit
Hi all just thought you'd like to know I've just found someone on ebay with the lower tailgate release button upgrade for £2.39, free carriage!!!!!!!!!!!!!!!!!! I know it might be a bit late for some of you, but for anyone new to the site, blinding result!!!
link;
http://www.ebay.co.uk/itm/231079164717
Post #270967 15th Jul 2014 9:53am
good find.. Thumbs Up
if you have a LR dealer near you then you can get one there for about £1.50.. ... - .- -.
Post #270969 15th Jul 2014 10:09am
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Yeah but, It would cost me a tenner in PETROL for return trip to the main stealer
Rolling with laughter Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #271033 15th Jul 2014 5:13pm
miggit
I've got an oil burner and a LR main dealer 5.5 miles away, and I reckon that it would workout more expensive, plus I can smurf the web and let the postie do the work Very Happy
Post #271083 15th Jul 2014 9:31pm
miggit
I have been looking in to doing this conversion on my ffrr, but, it would appear that the boat has sailed on reasonably priced parts. The current price from Dan is £63 Shocked Shocked , no reflection on Dan, I know if it can be had cheaper he'd do it. L/R are taking the urine with thier prices, I can only imagine that they have sold a few more brackets than 2011-2012 ffrr's and have relised that there is a retro fitting frenzy, and have adjusted the prices accordingly Evil or Very Mad
So, not to be done over by the stealers, I have been looking in to making my own bracket and saving best part of £30. The first bit of good news is you don't have to buy a new strap, I took a torques bit to my ffrr today and discovered that the top bolt is a bolt Wink
This means that it can be substituted with a ball stud and a hole made in the rubber cover and you've saved £15 ish Mr. Green BUT, the best priced ball studs have a minimum order and I'd end up with enough for half a dozen plus conversions Shocked I've only got one Big Cry Anyone else interested? £2 + postage for 1 long ball stud for the strap and 1 short for the bracket.
I have also been rummaging in my pals scrap pile, and he has some 2.5mm 3" rolled c section that I think will make a nice bracket, similar to the L/R one, but from his scrap pile, with price adjusted favorably Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #323767 22nd Apr 2015 9:20pm
