![]() | Home > Maintenance & Mods (L322) > leaking FF! |
Sunroof drain blocked in the A pillar?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
Sunroof drains...........? 2011 Range Rover Vogue SE 4.4 TDV8
Ah, Craig must have beat me by a few seconds...........
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 ![]() ![]() |
Thanks guys, its still raining so won't need to add any water,..
The school of thought if you look on the net, appears to be to use compressed air up the tube in reverse.
spot on, thanks guys! Definitely the s/r drain on the driver side.
Not sure on the L322, but I'd imagine you'd have to take the inner wheel arch liner out....
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Bicycle brake cables are usually good for this. You can often get a 5m piece from your local bike shop for around £1. If the end frays a little they are even more effective, but get harder to work with. |
Ah, the pleasures and smugness of owning an HSE..... |
