Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 11 of 49 <123 ... 101112 ... 474849>
yes you can just alter the access mode, have a read re height calibration here...
http://www.fullfatrr.com/gallery/albums/us...9-RR02.pdf ... - .- -.
Post #137053 21st Aug 2012 7:00pm
SteveMFr
Site Sponsor
Hi Lolo
Live Values - IPC Instrument Pack ;
- Next Service in x km
- Service Period x km
The next service is calculated base on a 12000km service interval.
If the service period is 24000km then you need to add 12000km ;
- if the number is positive, ex: 1500km , 1500+12000 = Next service in
13500km
- if the number is negative, ex: -5000km , -5000+12000 = Next service in
7000km
This will be changed in next release. We added this very quickly in the last update.
You may need to update again to the latest 2.17 before seeing the option.
Blackbird - Thanks! Thumbs Up
Drakes - before doing another update (this has never caused a prob to date) please check for connectivity between the IIDTool and the OBD port. When you plug in, the LED on the side of the IiDTool will blink several times. it will also stay lit when a command - cruise control - button is pressed.
We've had numerous cases of poor connectivity due to loose connectors in the OBD port.
Please post back and let us know.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #137068 21st Aug 2012 7:52pm
SteveMFr
Site Sponsor
spanner wrote:
Hi all
will this tool alter the height settings in so much as keep original ride height but alter access height for instance
Thanks
Hi Spanner,
Please update your profile. As Stan said, you can do this separately with the IIDTool (it is the only device that allows this, btw) - but up to now only for the 02-05 L322. We will work on implementing this for the other vehicles at a later date - it's relatively complex to do.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #137074 21st Aug 2012 8:02pm
Cash2
United Kingdom 2018 Range Rover Autobiography TDV6 Santorini Black
IID Tool
I have joined the list of happy IID Tool users but, once you start using it you end up with more questions and my first question is - what is the Vehicle information and communications system ? it is set to No currently,
My second question is how do you enable the FMH lights, I have tried several options with the IID Tool?
Many thanks for all of the good advice and posts on the forum.
Post #137978 27th Aug 2012 4:10pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
@Cash2
Does this help? http://en.wikipedia.org/wiki/Vehicle_Infor...ion_System
It's basically Japanese TMC as far as I am aware.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #138000 27th Aug 2012 5:37pm
Cash2
@ TheAllSeeingPie
Many thanks for this reply - I can disregard the VIC now.
This is my third FFRR but I never got involved more than to drive and enjoy, now I am intending to do as much as I can i.e Oil change, brakes and the like instead of going to the main dealers for everything.
Any help with the FMH issue would be appreciated...
Post #138002 27th Aug 2012 5:50pm
TheAllSeeingPie
For the FMH you have tried a flash of your high beams after turning the ignition off? They aren't an automatic thing and require you to request them to be on.
Post #138096 28th Aug 2012 7:05am
Cash2
Ok thanks I will try that this evening..
Post #138117 28th Aug 2012 10:51am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I also set the car to have all lights on front and back including fogs for the FMH, really lights up the area and might even surprise the neighbours! Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #138173 28th Aug 2012 6:46pm
mpirie
The IID tool has to be one of the best OBD tools out there.
Does anyone know if you can extract (to pc or mac) what the current configurations are set to?
I know you can save your configuration to the tool, but can you print it out or download it instead of having to sit at the dash reading the screen?
Mike
Post #138192 28th Aug 2012 7:41pm
i dont think that's possible mike..the pc connection [afaik] is only for software updates... ... - .- -.
Post #138194 28th Aug 2012 7:44pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
@Trevor, another stupid question, have you made sure the hand brake is off?
Sorry obvious I know but it caught me out once!
Post #138196 28th Aug 2012 7:53pm
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Hi chaps
Can someone post me a Noddy's guide to getting the central locking working the way I want - I've got the speed related locking working fine, but when I get out of the car, only the driver's door unlocks, and I have to press the key fob again to unlock the boot and/or other doors. I find this mildly annoying but I've tried various permutations but not succeeded.
Incidentally, what is the difference between "Speed related locking Repeat" and "Speed related locking, keys 1-4"?
Post #139249 3rd Sep 2012 5:31pm
TheAllSeeingPie
The "repeat" means if you're on the move and someone hits the unlock, it'll just re-lock automatically.
Post #139289 3rd Sep 2012 8:00pm
SteveMFr
Site Sponsor
Hi nubbin,
Check the 'Single Point of Entry' settings for whatever # key you have.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #139457 4th Sep 2012 8:21pm
