Home > In Car Electronics (L322) > 2002 Multimedia Blue rectangle
stutvt
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
My 2002 HSE has a touch screen multimedia system fitted, but when i try to use the sat nav or play a dvd I have a blue rectangle appear on the screen which blocks about 20% of the screen.
`Does anybody know what causes this or how to cure it?
Post #141384 16th Sep 2012 4:33pm
This sounds like an after market unit, what make/model is it, how is it connected up to the car? .
Post #141388 16th Sep 2012 4:47pm
stutvt
Im not sure what make it is, even the manual does not have a brand name on it!
Post #141389 16th Sep 2012 4:48pm
mjdronfield
Have you got any pictures ?
Does it say a brand name when it powers on ?
Assume it doesn't or you'd have seen it.......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #141397 16th Sep 2012 6:06pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
As the 2002 had no touch screen *ever* - it is aftermarket. Is it one of these?
http://www.powerfuluk.com/products/range-r...d-etc.html Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #141446 16th Sep 2012 10:48pm
stutvt
When the system boots up there is a red & black emblem, which i don't recognise but it has two R's on it!
Unfortunately i dont have the car with me today but i will try to post pictures tomorrow.
It looks abit like the one on the link above just with a few more side buttons & different on screen menus.
Post #141575 17th Sep 2012 3:25pm
stutvt
My unit is identical to the one in this video.
Post #141580 17th Sep 2012 3:36pm
these chinese units use the win ce operating system and normally with a reboot will work ok... ... - .- -.
Post #141583 17th Sep 2012 3:47pm
stutvt
How do i reboot the system?
Disconnect battery?
Post #141588 17th Sep 2012 4:10pm
unless you can find a fuse for it...take out any sd cards and follow the dis-connection procedure in the wiki..not saying this will cure your problem but you have to start somewhere. ... - .- -.
Post #141590 17th Sep 2012 4:20pm
stutvt
Thanks i will try that tomorrow.
You mention remove an SD cards, sorry to sound stupid but where is the sd slot?
Post #141594 17th Sep 2012 4:40pm
sorry ,thinking about my old nav unit..i dont think yours has one .. ... - .- -.
Post #141600 17th Sep 2012 5:18pm
stutvt
I removed the fuse for a good hour and restarted the unit, still blue rectangle!
Censored
Post #142245 20th Sep 2012 9:18pm
