![]() | Home > In Car Electronics (L322) > 2002 Multimedia Blue rectangle |
stutvt Member Since: 12 Sep 2012 Location: Cornwall Posts: 7 ![]() ![]() ![]() |
My 2002 HSE has a touch screen multimedia system fitted, but when i try to use the sat nav or play a dvd I have a blue rectangle appear on the screen which blocks about 20% of the screen.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
This sounds like an after market unit, what make/model is it, how is it connected up to the car? .
Im not sure what make it is, even the manual does not have a brand name on it! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Have you got any pictures ?
As the 2002 had no touch screen *ever* - it is aftermarket. Is it one of these?
When the system boots up there is a red & black emblem, which i don't recognise but it has two R's on it!
My unit is identical to the one in this video.
these chinese units use the win ce operating system and normally with a reboot will work ok... ... - .- -.
How do i reboot the system?
unless you can find a fuse for it...take out any sd cards and follow the dis-connection procedure in the wiki..not saying this will cure your problem but you have to start somewhere. ... - .- -.
Thanks i will try that tomorrow.
sorry ,thinking about my old nav unit..i dont think yours has one .. ... - .- -.
I removed the fuse for a good hour and restarted the unit, still blue rectangle!
