![]() | Home > Technical (L322) > Restricted Performance Warning |
duka Member Since: 11 Jan 2011 Location: uk Posts: 147 ![]() ![]() |
Other than the handbook stating 'contact the dealer' only clues wo why this would have just happened on TDV8 4.4 - my wifes car & she's stuck back of nowhere hence the Q
Could just be the DPF needs cleaning. If she turns it off waits a few minutes and then if all OK try to drive it in high revs for a while to clean it out...
On the other hand it could be a turbo problem but lets hope not:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
2010 car so it will under warranty but its the hassle of getting it done...hope its not a big problem DUKA.. ... - .- -.
Yes more important that your wife's OK.... |
We've been through the DPF 'clean' regime a few times with too town driving. Wife has managed to limp car home with lots of irrate drivers (even with hazards on) as she could get it above 12-15mph - now awaiting a laptop to find the error codes.... will update for all when known, hopefully a turbo pipe rather than an actuator or turbo...!! |
AA there now (via LR Recovery) plugged in laptop and they can't find any errors.
i doubt if they have every manufacturers codes tbh, probably only the general ones which , in your case wont show any errors.. ... - .- -.
seems it was an engine shut down valve which was faulty, didnt get to speak to mechanic as he's out on a test drive, but aleast it's not turbos |
thats good news ...so back on the road later today then... |
Engine shutdown valve as in a valve that stops/opens the fuel flow to the engine ??
