Home > Maintenance & Mods (L322) > Jacking an FFRR for wheel changing
Found this on the Disco 3 site.
Haven't tried it yet but have a feeling it would work on FFRR.
Look also at the pictures in CUCO's gallery.
Could well be easier and safer than using LR supplied jack.
I appreciate LR wouldn't approve, but I don't approve some of the things they do / recommend.
Wheel Changing
Post #146397 15th Oct 2012 8:30am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Direct link to the gallery they are all talking about: http://www.disco4.com/gallery/index.php?cat=25524
Very impressive indeed, might even find a level car park later and try it out (my drive is about a 25 degree slope).
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #146401 15th Oct 2012 9:00am
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
I've used this method since I've had my P38, basically extend the suspension as far as possible, use an axle stand or similar under a suitable point by the wheel/wheels you want and lower Thumbs Up
Post #146424 15th Oct 2012 11:12am
steptoe
Used to use this method on my citroens more than 20 years ago Very Happy
Post #146425 15th Oct 2012 11:13am
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Check the trolley jack adaptors in the D4 and Sport forums.
Make one without the locating peg on top and weld a piece of 30mm square steel 54mm long on top instead. This then locates in the sockets provided for the scissors jack and makes a securely located method of jacking the FFRR safely and easily.
I have a similar one for my MY12 Westminster and of course a suitable trolley jack.
Post #146448 15th Oct 2012 12:58pm
oldcro
Double post again. Censored
Post #146449 15th Oct 2012 12:58pm
Hamish
England 2002 Range Rover HSE Td6 Java Black
I managed to bend my scissor jack at the side of the motorway in the dark whilst it was Censored down. Gave up eventually called the nice man from the RAC who thought it should be loaded onto a trailer for a flat tyre, told him to f off and got down myself and got dirty with some help from the airsuspension and a very shaky scissor jack. Mr. Green
Post #146451 15th Oct 2012 1:03pm
