Home > Maintenance & Mods (L322) > Bleeding brakes - please help
MBR
Scotland 2003 Range Rover Vogue Td6 Zermatt Silver
Hi all,
I recently fitted new brake pipes to my 2003 td6. After bleeding the brakes I have a good solid pedal just as it should be. When the engine is started and pressure put on the brake pedal it slowly sinks to the floor. Thinking this may be a faulty master cylinder I replaced it with a new one but the problem is still the same.
I am fairly confident that the brakes are bled properly and was wondering if the pre charge pump might be the cause.
Does the pre charge pump need to be bled and if so does anyone know how to do it?
Any help will be gratefully received.
Many thanks
Mike
Post #146632 16th Oct 2012 6:41pm
IS the pedal going right to the floor, if I sit still and press the pedal with the engine running the pedal sinks almost to the floor if enough pressure is applied, but when driving the pedal feels fine and at MOT time the tester was well impressed with the brakes
Post #146633 16th Oct 2012 6:43pm
MBR
Hi,
Pretty much down to the floor. On the road the brakes work perfectly but as it's MOT time I am thinking it will not pass.
Post #146634 16th Oct 2012 6:50pm
If the pedal feels fine on the road then I would leave it
Post #146637 16th Oct 2012 7:19pm
MBR
Thanks, I will book it in for an MOT and see how I go on
Post #146640 16th Oct 2012 8:23pm
Mine does the exact same pedal to the floor on start up but when travelling the brakes work fine , have to admit at first i thought there was something wrong too .. Thumbs Up
Post #146641 16th Oct 2012 8:42pm
I noticed mine did the same thing when I bled the brakes, I thought I had a leak at one of the joints as I had replaced flexi pipes and calipers, but once out on the road the brakes are shiit hot...Nothing to worry about
Post #146643 16th Oct 2012 9:12pm
As been said mines the same. Feels Censored but if I put that much force into the peddle while driving I would be scraping my face off the steering wheel! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #146644 16th Oct 2012 9:26pm
MBR
many thanks for all your replies. It makes me feel much happier to know that this is normal. I have spent the last two weeks checking and double checking everything I can think of.
Your input has been much appreciated.
Mike
Post #146646 16th Oct 2012 9:55pm
Pedal creep by applying continuous pressure to the brake pedal is very common on diesel engined cars due to the vacuum available from the engine mounted vacuum pump. Basically there is generally to much vacuum available.
The problem is well known to VOSA who have in fact issued guidance to mot testers regarding the problem.
If the problem is pedal creep as you describe it is not a problem, it is a characteristic of brakes on diesel engined cars and is of no concern.
The simple answer is, don't sit and apply constant pressure to the brake pedal when stationary.
Provided your brakes operate when required to the necessary standard your brakes are fine.
I've come across this on a number of cars in the past some models are worse than others.
Post #146650 16th Oct 2012 10:12pm
MBR
An update
Hi all,
Just thought I would give you this update.
Today my FFRR passed it's MOT with no advisories.
Many thanks for all your input.
Mike
Post #151310 15th Nov 2012 11:28am
RCusden
Wales
+1 on what nicedayforit said spot on Thumbs Up
Roger
Post #151404 15th Nov 2012 8:02pm
Pepi
Surely this can't be right!
Same problem but on a 2004 L322 4.4 petrol
This seems more noticeable now after Fitting new callipers and discs.
I have drained fluid refilled and bleed through Using (Gunson Easybleed). No bubbles clean fluid no leaks as it should be.
Pedal does not inspire confidence.
I have had a similar problem with a Freelander TDi but no where near a pronounced as this.
Surely this can't be right.
Possible Comment welcome😏🚘
Post #327346 12th May 2015 9:48am
Weegie
One of the ways of testing if your brake power assistance is working is to have pressure on the pedal when starting the engine. If it sinks a bit further then the servo is working if it doesn't then there is a possible problem with the servo.
If this is what you are experiencing I wouldn't worry. The pressure on the pedal when starting should be as if you were trying to brake not just putting your foot on it to satisfy the RR starting procedure.
HTH John
GAP iiD BT-Sold
Post #327380 12th May 2015 11:24am
Pepi
Hi thanks for the return.
No it's more than that!
To discribed it a little better, once you have started the car and all system check have been done by the car you can put pressure on the pedal and it will slowly continue to go down. A similar but slower feeling to bleeding.
I know the process you are referring to and have done this as a servo check but this is not quite like that. It is not like when the master cylinder or the servo is starting to fail either. I have experienced all those in past exploits over the years.
Just didn't know if anyone knew of any idiosyncrasies with The Range Rover L322 2004 4.4L in particular. Confused Eddie the eagle watch out 👀
Post #327415 12th May 2015 1:45pm
