![]() | Home > Maintenance & Mods (L322) > Bleeding brakes - please help |
MBR Member Since: 29 Sep 2012 Location: Tongue Posts: 23 ![]() ![]() ![]() |
Hi all,
Hi,
If the pedal feels fine on the road then I would leave it |
Thanks, I will book it in for an MOT and see how I go on |
Mine does the exact same pedal to the floor on start up but when travelling the brakes work fine , have to admit at first i thought there was something wrong too .. |
I noticed mine did the same thing when I bled the brakes, I thought I had a leak at one of the joints as I had replaced flexi pipes and calipers, but once out on the road the brakes are shiit hot...Nothing to worry about |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
As been said mines the same. Feels |
many thanks for all your replies. It makes me feel much happier to know that this is normal. I have spent the last two weeks checking and double checking everything I can think of.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Pedal creep by applying continuous pressure to the brake pedal is very common on diesel engined cars due to the vacuum available from the engine mounted vacuum pump. Basically there is generally to much vacuum available.
Hi all,
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
+1 on what nicedayforit said spot on |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 ![]() ![]() |
Same problem but on a 2004 L322 4.4 petrol
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
One of the ways of testing if your brake power assistance is working is to have pressure on the pedal when starting the engine. If it sinks a bit further then the servo is working if it doesn't then there is a possible problem with the servo.
Hi thanks for the return.
