![]() | Home > Maintenance & Mods (L322) > Climate Control Manual select not working |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
I tried to use the manual select from the touch screen last week and it did not work.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
if you're on about the fbh, then maybe the outside temperature is not cold enough.. ... - .- -.
Stan
thats cold enough .. |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 ![]() |
when you say it didnt work ...was it grayed out ? Bluetooth Exchange www.bluetoothexchange.co.uk |
It was not grayed out, in fact when pressed it registered the press started the heater fans and then stopped so suggests fuses are OK.
Sounds like a low voltage issue Bluetooth Exchange www.bluetoothexchange.co.uk |
