![]() | Home > Maintenance & Mods (L322) > Climate Control Manual select not working |
| IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502
I tried to use the manual select from the touch screen last week and it did not work.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35876
if you're on about the fbh, then maybe the outside temperature is not cold enough.. ... - .- -.
Stan
thats cold enough .. |
| wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 |
when you say it didnt work ...was it grayed out ? Bluetooth Exchange www.bluetoothexchange.co.uk |
It was not grayed out, in fact when pressed it registered the press started the heater fans and then stopped so suggests fuses are OK.
Sounds like a low voltage issue Bluetooth Exchange www.bluetoothexchange.co.uk |
| All times are GMT |
