Home > Maintenance & Mods (L322) > Climate Control Manual select not working
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I tried to use the manual select from the touch screen last week and it did not work.
The car was in for a service on Tuesday this week and I mentioned the problem along with the lack of auto lights and auto wipers, prior to the car going in.
Got a call to say they would need it for two days as the auto problems were in the depth of the dash, no problem for me but got a call on Wednesday to say auto problems fixed, poor connection, but the climate control was OK it only works on timer or remote.
I suggested they read the handbook, clearly states you can manually select, so they did and came back to me to say I was correct but they would need more time to investigate so sent the car back as it is going in again for an upholstery repair and they will fix it then.
They also said another customer came in with the same problem.
Ian
Post #146957 19th Oct 2012 8:45am
if you're on about the fbh, then maybe the outside temperature is not cold enough.. ... - .- -.
Post #146965 19th Oct 2012 10:12am
IanV8
Stan
It was 3C so should be cold enough.
Ian
Post #147010 19th Oct 2012 2:33pm
thats cold enough .. Wink
i guess the engine was stone cold as well....if so and it still didnt fire then maybe a fuse.. ... - .- -.
Post #147027 19th Oct 2012 3:09pm
wiggs
when you say it didnt work ...was it grayed out ? Bluetooth Exchange www.bluetoothexchange.co.uk
Post #147256 20th Oct 2012 11:56pm
IanV8
It was not grayed out, in fact when pressed it registered the press started the heater fans and then stopped so suggests fuses are OK.
Car is going back in so they can look at it and they will have to fix the audio as well as when I used the car on Saturday the radio only worked for about 5 minutes then nothing, no CD no voice on sat nav, came back after being switched off but then gave up again.
Ian
Post #147412 22nd Oct 2012 7:44am
wiggs
Sounds like a low voltage issue Bluetooth Exchange www.bluetoothexchange.co.uk
Post #147482 22nd Oct 2012 1:14pm
