Home > Wheels & Tyres > Wheel options for a MY2007 Supercharged?
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Hi all,
Just wondering if I can go to 19"s on a SC? Mainly because I'd like to have separate winter wheels. I'm also considering the possibility of Compomotive 18"s which should fit if I move the brake weight blocks around, but not sure the Bowler Wildcat look is for me ...
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #149967 6th Nov 2012 11:59am
pretty sure you can go 19'' but they must be able to fit around your brembo brakes so i think only the newer wheels [2009?] will do the job... ... - .- -.
Post #149968 6th Nov 2012 12:01pm
Charmer
I have fitted 19" wheels, for the Winter, on my 07 Vogue SE TDV8 with Brembo Brakes.
Need to make sure you buy post 2006 wheels or you will also need to change the wheel nuts as well.
Post #150020 6th Nov 2012 6:48pm
They are for a 2007 SC so should be the later nuts anyway...
But for info's sake, pre 06 wheels have holes in between the wheel nuts and post 06 wheels have dimples in between ...
Craig Thumbs Up
Post #150029 6th Nov 2012 7:54pm
that'll be the seven spoke 20" you're talking about Craig..... ... - .- -.
Post #150038 6th Nov 2012 8:11pm
NKSC
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
I used to have 19's on my SC and they were fine. As Stan says, they were a newer style, so not sure about the older ones.
Post #150068 7th Nov 2012 7:36am
