![]() | Home > Maintenance & Mods (L322) > Swap Chrome Tubes for Side Steps Anyone? |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Probably best with OEM ones , as there have been a couple of folk who have bought OEM style ones and the fittings are out by a few mm and don't line up correctly |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
I have the OEM ones and my girls use them all the time. No slipping has occurred yet. MY 2010 5.0 SC Galway green and sand interior!!
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
Would you not need to change the front mudflaps also ? 2011 Range Rover Vogue SE 4.4 TDV8
Yeah he will have to do that also but i am sure the OEM ones come with the front flaps |
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
I've got a set of OEM ones that are sat in the garage. They have the mud flaps but don't have any bolts (had to cut them off to get the steps off). They have a couple of small dings on the underside but these aren't noticeable when they are on the car. You're welcome to them for £100 although posting them might be a nightmare as they are big and heavy. |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Just get some rubber treads stuck to the tubes |
Re the flaps, the OEM ones come with the front flaps, but the side tubes don't (AFAIK) so if you have OEM ones and swap for tubes, you will also need new front mudflaps. 2011 Range Rover Vogue SE 4.4 TDV8
| ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276
I've been toying with the idea of chrome side bars instead of the steps that I have. We never use the steps as I'm 6ft2in & SWMBO is 5ft11in so getting into the car is not a problem.
| marcoos_1 Member Since: 25 Oct 2012 Location: Glasgow Posts: 138
Thanks guys.....I hadn't thought about the mudflaps. I should have remembered as I fitted them when I fitted the steps to the P38.
I would imagine you'd swap them with the tubes for the ones for the steps.
The OEM ones bolt into the same place regardless of the recess for the steps or not. As I said I have OEM sidesteps and mud flaps sat in the garage if you're interested. All you'll need is some bolts from the hardware store (about 6-8 bolts for the steps, you can recycle your mud flaps bolts) and you'll be set. |
Thanks guys.
| woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259
I'd like to jump on this topic too! I also have chrome tubes and would like to swap them for OEM steps or similar, as my dear old granny cannot get it without me having to help her up. Steps would be more convenient although I do prefer the tubes.
It's proving difficult....I PM'd the guys who replied but haven't been able to sort anything out yet.....not sure if they changed their minds.... |
| All times are GMT |
