![]() | Home > Maintenance & Mods (L322) > Anyone cooked their lights |
i think you will find the rears are glued/bonded and dont come apart. V8 facelift Range Rover Autobiography 22" wheels.
The rears are heat welded so cannot be removed unfortunately... |
Stuart's the man Member Since: 16 May 2012 Location: Glasgow Posts: 94 ![]() |
Thanks Guys, a new one it is then |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Cook them?? |
Heat them up in the oven sao that you can split the lens from the light |
Ahhhhhhh fair enuf, not heard that one, when I changed my front lens I had no issues swapping it for the new one |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
is it possible to change the front indicator lens also? MY2010 TDV8 Vogue Ipanema Sand
never mind... |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
You can certainly heat the indicators in the oven to split the lenses... I have one done at home...
If I can remember correctly, 10-15 mins at 50 degrees, then check - glue should be starting to melt at this stage - I think we put it back in for another 10 mins.
Oh, and whilst I remember - getting the chrome bits out was a lot more difficult! Had to drill out the 3 points where it was glued from behind - not recommended!!! l:OolΞΞΞΞΞΞloO:l
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
What side do you need? I've got an offside one if you want to buy it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
