Home > Maintenance & Mods (L322) > Anyone cooked their lights |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
i think you will find the rears are glued/bonded and dont come apart. V8 facelift Range Rover Autobiography 22" wheels.
21st Nov 2012 10:14pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
The rears are heat welded so cannot be removed unfortunately...
22nd Nov 2012 12:41am |
Stuart's the man Member Since: 16 May 2012 Location: Glasgow Posts: 94 |
Thanks Guys, a new one it is then |
23rd Nov 2012 9:48am |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 |
Cook them?? |
23rd Nov 2012 8:33pm |
Heat them up in the oven sao that you can split the lens from the light |
23rd Nov 2012 9:47pm |
Ahhhhhhh fair enuf, not heard that one, when I changed my front lens I had no issues swapping it for the new one |
23rd Nov 2012 10:01pm |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
is it possible to change the front indicator lens also? MY2010 TDV8 Vogue Ipanema Sand
26th Nov 2012 12:22pm |
26th Nov 2012 1:10pm |
never mind... MY2010 TDV8 Vogue Ipanema Sand
26th Nov 2012 1:14pm |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 |
You can certainly heat the indicators in the oven to split the lenses... I have one done at home...
26th Nov 2012 2:06pm |
26th Nov 2012 11:53pm |
If I can remember correctly, 10-15 mins at 50 degrees, then check - glue should be starting to melt at this stage - I think we put it back in for another 10 mins.
27th Nov 2012 11:28am |
Oh, and whilst I remember - getting the chrome bits out was a lot more difficult! Had to drill out the 3 points where it was glued from behind - not recommended!!! l:OolΞΞΞΞΞΞloO:l
27th Nov 2012 11:29am |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
What side do you need? I've got an offside one if you want to buy it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
7th Dec 2012 9:36am |
