Home > Maintenance & Mods (L322) > Anyone cooked their lights
Stuart's the man
Hi
i know it is common to cook your front lights to remove the lens, i was wondering if anyone has done this to their rear ones, just picked up a nice big crack on my supercharged lights, and wanting to know if i can change a lens from an early one onto it
Post #152616 21st Nov 2012 9:36pm
daveo
i think you will find the rears are glued/bonded and dont come apart. V8 facelift Range Rover Autobiography 22" wheels.
Post #152629 21st Nov 2012 10:14pm
The rears are heat welded so cannot be removed unfortunately... Crying or Very sad
Craig Thumbs Up
Post #152664 22nd Nov 2012 12:41am
Stuart's the man
Thanks Guys, a new one it is then
Post #152840 23rd Nov 2012 9:48am
Deasy
Cook them??
Post #153016 23rd Nov 2012 8:33pm
Stuart's the man
Heat them up in the oven sao that you can split the lens from the light
Post #153027 23rd Nov 2012 9:47pm
Deasy
Ahhhhhhh fair enuf, not heard that one, when I changed my front lens I had no issues swapping it for the new one
Post #153030 23rd Nov 2012 10:01pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
is it possible to change the front indicator lens also? MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #153566 26th Nov 2012 12:22pm
Same as rears unfortunately... Sad
Craig Thumbs Up
Post #153583 26th Nov 2012 1:10pm
woodchopper23
never mind... Neutral MY2010 TDV8 Vogue Ipanema Sand
Post #153585 26th Nov 2012 1:14pm
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
You can certainly heat the indicators in the oven to split the lenses... I have one done at home...
Would have thought the rears would have been the same. l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #153607 26th Nov 2012 2:06pm
How did you do it? More info please...
Craig Thumbs Up
Post #153745 26th Nov 2012 11:53pm
T111RDY
If I can remember correctly, 10-15 mins at 50 degrees, then check - glue should be starting to melt at this stage - I think we put it back in for another 10 mins.
A lot of forums say a higher temperature, but SWMBO is a materials scientist, and did her post grad on adhesives, so I went with her lower temp!
You can also use a heat gun, but be careful not to melt the plastic...
I had a broken light that I was practising splitting, as it had been my intention to paint (or vinyl wrap) the indicators and headlights (and ultimately tail lights) along the lines of Googsy2 - but I ended up fitting lamp guards, and thought that having blackened lights, indicators, etc underneath may be going a bit far!
 l:OolΞΞΞΞΞΞloO:l
Post #153808 27th Nov 2012 11:28am
T111RDY
Oh, and whilst I remember - getting the chrome bits out was a lot more difficult! Had to drill out the 3 points where it was glued from behind - not recommended!!! l:OolΞΞΞΞΞΞloO:l
Post #153809 27th Nov 2012 11:29am
Andy
What side do you need? I've got an offside one if you want to buy it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #155931 7th Dec 2012 9:36am
