Home > Technical (L322) > [SOLVED] How do I test if my Auto Dipping Mirror is working?
With a tinted rear window, headlights aren't as bright as with a normal rear window.
How do I test if my auto dipping is working? .
Post #153367 25th Nov 2012 2:47pm
Shine a torch onto the mirror sensor
Post #153371 25th Nov 2012 3:09pm
BrianC
Are we talking about dimming or dipping ?
Is the switch on the door pushed to the left ?
Post #153374 25th Nov 2012 3:31pm
it'll be dimming...i got the same problem with my tints..kinda makes the auto dip redundent... ... - .- -.
Post #153383 25th Nov 2012 4:56pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Mine only seem to work when there isn't street lighting around, making me think it's something in the mirror that governs it (a bit like the auto lights).
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #153406 25th Nov 2012 7:58pm
I mean the rear view mirror (the one fixed to the windscreen).
If there is nothing more scientific than a torch, I'll try that first.... .
Post #153407 25th Nov 2012 7:59pm
The photocell is the little round circle in the top center of the rear view mirror. A torch should do the trick. It should dim both wing mirrors and the rear view mirror. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #153411 25th Nov 2012 8:41pm
Can't you override it by turning the red light at the bottom of the mirror one way? Sure that's what the manual says for manual dipping. Confused Si. <This is my name.
Post #153427 25th Nov 2012 9:28pm
It works.
1. Make sure it is dark
2. Get a suitable torch
3. Jump in the car and start up
4. Put thumb/finger over the small round sensor at the middle top of the mirror
5. Turn on torch (holding in your left hand so you can see the beam reflecting in the mirror with your eyes)
6. Shine torch at mirror so you can see the beam reflection
7. Get used to the intensity
8. remove thumb from sensor
9. If working, the intensity of the beam should gradually diminish.
10. Test again to make sure Wink
11. Switch off car
12. Clean thumbprints from mirror Thumbs Up .
Post #153440 25th Nov 2012 9:52pm
