|  | Home > Technical (L322) > Range starting problem |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | sounds like the battery....if the original is over 3 years old then its time to get a new one." ... - .- -.
|  25th Nov 2012 8:42pm |
| Glm Member Since: 09 Dec 2011 Location: Manchester Posts: 105      | Cheers stan thats what I am hoping as I have it on charge ! When I fitted charger it only registered 7.6 volts ? Current tdv8 range vogue 07 | ||
|  25th Nov 2012 8:44pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | if that battery is still ok then that voltage should rise.. ... - .- -.
|  25th Nov 2012 8:46pm |
| Glm Member Since: 09 Dec 2011 Location: Manchester Posts: 105      | []
|  25th Nov 2012 8:49pm |
| Glm Member Since: 09 Dec 2011 Location: Manchester Posts: 105      | Just checked battery voltage is up to 11.6 but still nothing with key or lights Current tdv8 range vogue 07 | ||
|  25th Nov 2012 9:06pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | Fully charged it should be around 14.6 volts | ||
|  25th Nov 2012 9:11pm |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700    | Are you charging it on the car? Have you disconnected any leads? You should leave it charging overnight to give it a full charge. Previously..
|  25th Nov 2012 9:14pm |
| Glm Member Since: 09 Dec 2011 Location: Manchester Posts: 105      | Still connected but battery showing 12.4 volts but still key won't turn and stilll no lights! Will disconnect in morning and leave on charge for the day whilst in work ! Current tdv8 range vogue 07 | ||
|  25th Nov 2012 11:03pm |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700    | I think unless it's a battery conditioner type charger you can damaged the car by not disconnecting the battery.
|  25th Nov 2012 11:07pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | []
|  25th Nov 2012 11:31pm |
| oliver9627 Member Since: 25 Oct 2012 Location: Chipping Norton Posts: 51      | Glm
|  26th Nov 2012 5:29pm |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782      | Oliver, have you checked the voltage while the engine was running ?? It is probably in the 14+ volt range i.e. the alternator is charging the battery, masking the imminent death of the battery.
|  26th Nov 2012 6:22pm |
| Posting Rules
