![]() | Home > Technical (L322) > Won't start, help.!!! |
Worth getting the alternator checked to avoid ruining another battery... |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 ![]() ![]() ![]() |
hello i had the same problem, relay under the ignition key part bmw 61326901961 |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
Expensive for part? Easy to change?
I've got the original, you never know which bmw over the years may have modified the original replacement ... cost 70 euro, but there is also competition (valeo) very simple work .... |
The weird thing is the key turns fine steering wheel unlocks..I hear an electric clicking sound at the ignition.. |
sometimes feels a beep and a zzzzzzz near the gear selector .... |
This sounds spot on, I just got the car started before tow company came out.ok this may sound like a ridiculous question but can I just spray some contact cleaner into the ignition or will that f |
I tried, just that you can not do get the product into the ignition, the contacts are on the side, you have to remove the butt of the lock
From searching the forum I have nailed the intermittent starting problem down to 2 possibilities:-
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
Hi Lolo
Hi Patrick,
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746 ![]() ![]() |
Does sound like the same problem I had, not too bad a job to do |
Hi Lolo
