Home > Technical (L322) > Transfer box motor?
Page 1 of 7 1234567>
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Transfer box motor?
Hi guys
My 2004 td6 has had a few issues and after taking to a specialist I've been told it needs a transfer box motor! After enquiring with LR and the part is £1300??
Does anyone know of a good second hand one available for reasonable money or where to start looking?
Also I've been told it has play in the front prop shaft but requires an upgraded unit??
Any advice I'd be greatful.
Thanks in advance
Post #156022 7th Dec 2012 7:22pm
ahebron
New Zealand
Have a search round the internet looking at Land Rover parts companies. Even ask the sponsors of this site.
I paid 1/3 that price for an aftermarket branded unit that looked identical to the faulty one I removed.
Make up your own mind about fitting that or a genuine one.
I worded this reply so it does not offend those who will never use non LR parts or those who have a bee in their bonet about certain aftermarket brands
Adrian VW Amarok 2014 Highline auto
Post #156039 7th Dec 2012 8:30pm
SATVC
Thanks for the reply!
I've found the motor for around the £575 mark but non genuine LR?
To me that's more reasonable for an item that'll be rarely used as Im not much of an offroader!
I'm not to worried about genuine items aslong as they work properly! Lol
Post #156041 7th Dec 2012 8:36pm
Someone posted about this recently. I think it was RRPhil. Someone on another site has been making a new part for the motors. They fail on a sensor of some sort and can only be sorced as a complete unit. This guy was making the faulty part at a fraction of the price. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #156044 7th Dec 2012 8:45pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Look in ebay.de and search for BMW X3 or X5 Stellmotor VTG or Verteilergetriebe Motor, price is always around 300 - 400 Euros. Regaaaaaards..... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #156097 8th Dec 2012 10:56am
RRPhil
Unfortunately the NV225 shift motor is unique to the Range Rover - the BMW’s only having single range transfer boxes.
It was gyrogypsy over on rangerovers.net http://www.rangerovers.net/forum/6-range-r...gypsy.html who was arranging to have the rotary potentiometers manufactured. Although people keep prodding him occasionally for updates it’s all gone quiet at the moment so I’m not sure exactly what progress he’s making with this.
Phil
Post #156107 8th Dec 2012 11:49am
SATVC
Thanks for the info!
I don't mind paying £575 but everywhere is out of stock it seems??
Post #156115 8th Dec 2012 12:54pm
LRDirect have four types to choose from ("normal stock" to 1-3 days for genuine LR part)
http://www.lrdirect.com/IGH500010-Motorasy/?sfi=IGH500010
Also, we should mind having to pay over £500 for what is in essence a small electric motor (flymo strimmer Wink ) and some gearing! .
Post #156139 8th Dec 2012 3:41pm
SATVC
Ohh don't get me wrong I don't like having to pay out! Lol but I'd rather pay the £500+ rather than £1300
Thanks for the link. Ill give them a call on Monday! Are they a good firm to deal with?
Post #156141 8th Dec 2012 3:51pm
IIRC this is where I bought by new transfer motor from, online. Delivery 2/3 days. The new motor is still sitting in its wrapping waiting to be used Smile .
Post #156143 8th Dec 2012 4:04pm
RRPhil
Land Rover’s list price for IGH500010 is currently over £1600 incl. VAT
Less than two years ago it was £800
If/when gyrogypsy starts selling the potentiometer separately the price will, no doubt, drop significantly.
Land Rover are just making as much money as they can, while they can, because the product is unique to the L322.
Phil
Post #156144 8th Dec 2012 4:07pm
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi Phil, I've got this problem on my 03 V8 RR. It started in the bad weather when I used Lo range. Anyway I took the motor off today & it's only a 10 min job with 3 10mm bolts and a multi pin plug. I got the "transfer box in neutral" message on the dash.
The reason for mentioning this is I stripped the motor down and the problem seems to be the bushes on the motor. They are all broken & worn, even though the car has never been used off road so has had minimal use. I took it to Ellison's in Blackburn and they will ring me on Monday to let me know if they can fit new brushes in the motor. They said it shouldn't be a problem. I'll post back on how it all goes. Thought I'd mention it as I know you live in Blackburn, I'm only up the road from you in Darwen. Range Rover 4.4 V8 Vogue
Post #156149 8th Dec 2012 4:59pm
@Phil
Where does this potentiometer sit in the motor assembly and why are they not avalible seperatly? How and why do they fail? Can hi/low range be selected manually without the motor? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #156153 8th Dec 2012 5:42pm
RRPhil
The potentiometer :
sits here :
You’d have to ask Land Rover why they aren’t available separately
I suspect they fail through lack of use – most of us hardly ever select low range so the potentiometer wiper just sits on the same part of the carbon track, year in and year out, and eventually the contact starts to ‘corrode’ and contact becomes intermittent
High and low ranges can be selected manually but you would have to remove the motor first, turn the lead screw :
by hand, realign the motor gear (by powering up the electric motor) and then replace it. Not exactly convenient!
Phil
Post #156308 9th Dec 2012 6:14pm
I will definitely now use mine more regularly. The ramp to the car park at work is quite steep, so I shall engage low range while I wait for the door to open.
Post #156311 9th Dec 2012 6:39pm
