![]() | Home > Technical (L322) > Perm jump start connector |
I can see some benefit of doing this but what is so hard about lifting the bonnet and connecting jump clamps to the the two connector posts provided in the FFRR ? They are easy to get to, and no special connectors needed? .
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3951 ![]() ![]() ![]() |
I charge mine using the towing electrics socket on the back - seems to work fine Obviously no good for jump start but fine for c- tek 7 amps and I don't need to open the bonnet or even the car |
The main reason I want something along these lines is to make jumping of other vehicles that much easier when I need to it. Knowing my luck I would install it and never need it again |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
Is it not something like this you want?!?
Although possibly only one..... |
A bit more realistic...!
They are a bit pricey |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
The only trouble with externally mounted connectors of any type is the risk of vandalism.
Would a suitable fuse not cover this though??
Thsi should do the job.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Do you have any idea how long it takes to pop the bonnet and lift it ???? He's a busy man. ![]() |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Will
Ha ha a Jeeves!! If the divorce goes well I could have the ex stuffed in the boot to perform such duties but it might be too good for her lol!!
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
I cant afford a Jeeves as the rangie has bled me dry |
