Home > Technical (L322) > Perm jump start connector
Page 3 of 6 <123456>
I can see some benefit of doing this but what is so hard about lifting the bonnet and connecting jump clamps to the the two connector posts provided in the FFRR ? They are easy to get to, and no special connectors needed? .
Post #156147 8th Dec 2012 4:43pm
I did it because you get a much better connection than clamps - I always struggled on the FF to get a really good connection - and they're not coming lose or falling off
I can also join 2 cables together for a really long (9m) run if I need to.
Not compelling reasons I agree, but I'm glad I did it.
Post #156152 8th Dec 2012 5:19pm
supershuttle
I charge mine using the towing electrics socket on the back - seems to work fine Obviously no good for jump start but fine for c- tek 7 amps and I don't need to open the bonnet or even the car Thumbs Up Geoff
Post #156429 10th Dec 2012 10:59am
The main reason I want something along these lines is to make jumping of other vehicles that much easier when I need to it. Knowing my luck I would install it and never need it again Very Happy
But having the ability to simply connect in and then be able to jump onto the other vehicles battery would be good, especially in the cold when wearing gloves one less fiddly thing makes life better Smile
I saw one once installed on an FFRR that came and picked something up from me when i lived in donny but i cant recall his ebay user ID to ask him about it Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #156430 10th Dec 2012 11:08am
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
Is it not something like this you want?!?
http://www.autotechnik.co.uk/ProductGrp/000200070001 l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #156436 10th Dec 2012 11:57am
T111RDY
Although possibly only one..... Shocked l:OolΞΞΞΞΞΞloO:l
Post #156437 10th Dec 2012 12:04pm
T111RDY
A bit more realistic...!
http://www.asap-supplies.com/marine/jump-start-power-connectors
Thumbs Up l:OolΞΞΞΞΞΞloO:l
Post #156438 10th Dec 2012 12:08pm
They are a bit pricey Sad And still jump posts that are close together as well Sad
I'd rather have something that is shielded and prevents shorts as much as possible Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #156439 10th Dec 2012 12:20pm
The only trouble with externally mounted connectors of any type is the risk of vandalism.
Any minded smart-a.se only has to bridge the terminals with a piece of metal and your car is potentially on fire shortly afterwards.
Apparently this is a problem with winches with external connections which aren't capable of being isolated when not in use.
To isolate the +ve terminal you may have to resort to a relatively expensive heavy duty relay or a relatively inexpensive battery isolating switch either of which would probably have to be installed under the bonnet somewhere.
Not sure by the time you add all this in it's just not easier to open the bonnet.
I think the solution adopted by Alistair above is the most sensible. Thumbs Up
Convenience with security.
Post #156440 10th Dec 2012 12:34pm
Would a suitable fuse not cover this though??
That way if it was shorted the fuse would blow first? im guessing the fuse would need to be at least rated to 100amp if not 140? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #156443 10th Dec 2012 1:04pm
Thsi should do the job.
http://www.ebay.co.uk/itm/150-AMP-MEGA-FUS...vi-content
I think they are called Maxi Fuses that are fitted to some new LR's next to the battery to help protect it from any shorts in the system feeding back to kill it. I had one blow on the Censored SSRR that killed itself thankgod. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #156445 10th Dec 2012 1:06pm
steptoe
Do you have any idea how long it takes to pop the bonnet and lift it ???? He's a busy man. Mr. Green
Post #156530 10th Dec 2012 7:07pm
Will
Your a FFRR driver just turn to the left and say "Jeaves, run along and jump start that peasant". Sit in the FF and let the butler fidle with the bonet and all that good stuff. Lol [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #156557 10th Dec 2012 8:45pm
Ha ha a Jeeves!! If the divorce goes well I could have the ex stuffed in the boot to perform such duties but it might be too good for her lol!!
Seriously its not a big pain doing the bonnet and hooking up but I would like something that's easier on my end of connection as I'm never happy with the connections 100% but they do the job Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #156563 10th Dec 2012 9:23pm
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
I cant afford a Jeeves as the rangie has bled me dry Big Cry
Am interested in these as well as the two times I've had to jump her,one the cables werent long enough and second time with my (new) longer cables we couldnt get a good enough connection to start first time,the battery is an awkward Censored to clamp to as too many cables and connectors in there already
Post #156585 10th Dec 2012 10:25pm
