Home > Technical (L322) > steering column adjuster.
Page 2 of 3 <123>
Martin
Site Admin
Post #149975 6th Nov 2012 2:08pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
What is easy...??? Razz But no problem, you only need to screw out the both inbus-screws,, and pull down the handmade black nut, then put in the new one, and that it was. If help, no problem, also you can call me in CLEAR and SLOW slangfree-school-English language, so I can help you when you are fixing. Regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #149983 6th Nov 2012 3:01pm
muffster
2002 Range Rover Vogue Td6 Java Black
Ok i removed all the trim today and it seems like the problem is that black nylon/plastic nut.
Poor design!
The motor is spinning the shaft freely but the nut has no turning effort just as if it has been stripped.
So, Meerbusch, can i get hold of one of these nuts from you?
Cheers.
Post #150570 10th Nov 2012 6:37pm
Meerbusch
Will build one for you tommorow, send me a PM about adress and PayPal..., regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #150577 10th Nov 2012 7:37pm
muffster
Excellent
How much to post to the uk
Post #150587 10th Nov 2012 8:38pm
Meerbusch
Hi muffster, would say around 30 Euro incl. shipping in a little package with tracking number, it is half an hour work, but not in black plastic, it is grey nylon, and worked per handcraft, not per computer. If interest, send me your paypal adress, I send you an moneyasking. Regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #150667 11th Nov 2012 5:34pm
muffster
Hello mate I sent you a PM.
How does the motor come out. It looks difficult to get to it.
Cheers
Post #150690 11th Nov 2012 7:25pm
Meerbusch
the motor can stay, it is flexible, only the two screws inbus L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #150721 11th Nov 2012 9:51pm
muffster
Ok, i'm finally going to attempt this at the weekend hopefully.
I got a new part, thanks to Meerbush (soory for the late reply)
my problem is going to be getting access to the motor to fit the new nut.
I'm not exactly small and trying to cram myself into the footwell is not easy. So, how do i actually get in to remove the motor?
Thanks.
Post #155740 6th Dec 2012 1:41pm
muffster
Anyone help?
Post #159154 21st Dec 2012 10:54pm
You could try removing the seat
Post #159159 21st Dec 2012 10:58pm
Meerbusch
Gentleman, very easy job, believe me! You must build out the two plastic-shapes at the steering-wheel (3 screws), also the shape in the footroom at the pedals, then you can take a little inbus with (german word: kleiner Ratsche mit Gelenk und Verlängerung), and screw out the two inbus bolts not complete out, only 80%, then with a plastic-tool the spindle push down, and then the old nut out, and the new nut in, you will see it. Then the two inbus, and all will function with some oil-spray.
Happy X-Mas from germany!!!!!! Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #159202 22nd Dec 2012 11:27am
Uli, have you taken into consideration the RHD & LHD issue? What maybe easy on a LHD may not be on a RHD or is it easy on both?
Craig Bow down
Post #159205 22nd Dec 2012 11:47am
Meerbusch
@ Craig, is the same way, LHD or RHD, when you work this for the first time, it is half easy, but when you do it like I the 10th time, I could work without eyes in a dark car..., it is a construction-mistake!!! RR-stealers, also mine in germany don´t want fit my part. because they can earn on a complete column much more...., here I could help my RR-friends with a cheap part, read the german AUTOBILD newspaper, No.28/2012, or look in google: Ulrich-Hudetz Range Rover, there it is to read about the steerings....
Post #159217 22nd Dec 2012 2:40pm
muffster
Hello gain Uli.
Thanks for the reply, but at the risk of sounding like a real dumbass, I've. Got no idea what you mean by screwing out the inbus bolts!
Post #159223 22nd Dec 2012 4:27pm
Page 2 of 3 <123>
