![]() | Home > Technical (L322) > Tyre Pressure Monitoring Problems |
How about you just get it fixed so that it works as intended?
504cash Member Since: 31 Mar 2010 Location: Reading Posts: 11 ![]() ![]() ![]() |
Well nine of my visits to the dealer have been under warranty so I havent had to pay,
Ask them to remove all sensors and the ECU - then I'll buy it off you. |
do you think it will still comee up on the instrument display "tyre pressure monitoring fault" even with sensors and ecu removed ? |
I have a feeling that if you disconnect the ECU then you wont get the error message as it's the ECU that sends the message to the instrument pack.
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Won't help , but I do sympathise. Biggest heap of crap invented. Just discourages proper regular visual checks of tyres. Throws so many faults it creates a "cry wolf" scenario.
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
Mine is disconnected - done by the previous owner; don't know how, but I do have normal tyre valves.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
Mines going back to the dealer in two weeks to have it sorted, been faulty since I got the car, 4 months now |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 392 ![]() ![]() |
FYI: I was told by my dealer that if tire pressure monitors have been removed and reinstalled more than
DO you know which dealer this was ?? Ill call them and ask them how !! thanks |
Stratstone of Mayfair I believe. They undertook all servicing prior to me buying the car. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD! |
Waiting to hear back from Stratstone Technical department..
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 ![]() ![]() ![]() |
does anyone know what the tolerance of the TPMS system is? I found that if the tyres are too hard it also causes a "system error" (no specific wheel indicated). I played around with pressures, but if you deviate by more than about 10kpa either up or down, it seems to get the system error.
sportin Member Since: 12 Mar 2011 Location: USA Posts: 26 ![]() ![]() ![]() |
My spare has the fault.......dealer offered to disable the monitoring for it, for $35.do not disconnect any ecu.....you will cause other problems 2006 RR 4.4 HSE
