Home > Technical (L322) > Tyre Pressure Monitoring Problems
504cash
United Kingdom 2006 Range Rover Vogue Supercharged Java Black
Does anybody know if this pointless system can be turned off !!?? Permantley!
I have had so many problems with my tyre pressure sytem on my Range Rover.
Its been in an out of the dealership so many times now, they have re-calibrated it, re-set it you name it they have done it.
I have even paid for 4 new sensors and had them fitted and calibrated and it still flashes on !
All I want is the system turned off, I dont care about it I will know if I have a puncture !
Can Anybody help ?
Post #15981 31st Mar 2010 2:59pm
dan_uk_1984
How about you just get it fixed so that it works as intended?
If you're taking it to a dealer and they have not fixed then why are you paying them!? Perhaps take it to a dealer than knows what they're doing?
Post #15982 31st Mar 2010 3:06pm
504cash
Well nine of my visits to the dealer have been under warranty so I havent had to pay,
apart from the last visit when I purchased 4 new sensors.
I just want it turned off for ever !
Post #15983 31st Mar 2010 3:09pm
dan_uk_1984
Ask them to remove all sensors and the ECU - then I'll buy it off you.
Post #15984 31st Mar 2010 3:25pm
504cash
do you think it will still comee up on the instrument display "tyre pressure monitoring fault" even with sensors and ecu removed ?
Post #15986 31st Mar 2010 3:51pm
dan_uk_1984
I have a feeling that if you disconnect the ECU then you wont get the error message as it's the ECU that sends the message to the instrument pack.
From memory the TPMS ECU is under the passenger seat, but I may be wrong and I CBA to look in the workshop manual.
However, knock yourself out:
http://green-oval.com/joomla/index.php?opt...;Itemid=29
Post #15987 31st Mar 2010 4:00pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Won't help , but I do sympathise. Biggest heap of crap invented. Just discourages proper regular visual checks of tyres. Throws so many faults it creates a "cry wolf" scenario.
Got them on a Laguna, different league, same crap.
Post #15989 31st Mar 2010 5:11pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Mine is disconnected - done by the previous owner; don't know how, but I do have normal tyre valves.
So whether the valves alone being replaced has turned it off, or whether some other stuff had to be done to the ECU, I have no idea. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #16048 1st Apr 2010 7:56pm
Mines going back to the dealer in two weeks to have it sorted, been faulty since I got the car, 4 months now Big Cry Discovery 4 HSE
1993 90 Tdi
Post #16059 1st Apr 2010 10:40pm
funnyguy1
United States
FYI: I was told by my dealer that if tire pressure monitors have been removed and reinstalled more than
twice, as I recently had to do dealing with wheel refinishing, the gaskets had to be replaced as part of a kit that
costs $79 US per wheel. My tire dealer was able to locate the rubber O ring gaskets that are apparently made by Ford that cost about 90 cents each, which we used.
Post #16101 2nd Apr 2010 4:31pm
504cash
DO you know which dealer this was ?? Ill call them and ask them how !!
thanks
Post #16126 3rd Apr 2010 11:33am
jayzee
thanks
Stratstone of Mayfair I believe. They undertook all servicing prior to me buying the car. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #16136 4th Apr 2010 1:09am
504cash
Waiting to hear back from Stratstone Technical department..
ill keep ypu posted Very Happy
Post #16228 6th Apr 2010 4:29pm
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
does anyone know what the tolerance of the TPMS system is? I found that if the tyres are too hard it also causes a "system error" (no specific wheel indicated). I played around with pressures, but if you deviate by more than about 10kpa either up or down, it seems to get the system error.
I had a "left rear tyre soft" error last week, and it was a true fault, the tyre was indeed at about 150kpa (normal for light load is 250 I think)
I looked at the settings in the CCF with my faultmate, and there are lots of parameters you can add for allowed deviation high and low, but most of them were set at "0", will try play around when I get time, just wondered if anyone knows the "standard" allowed deviation.
Post #67426 7th Jun 2011 2:03pm
sportin
United States 2006 Range Rover HSE 4.4 V8 Java Black
My spare has the fault.......dealer offered to disable the monitoring for it, for $35.do not disconnect any ecu.....you will cause other problems 2006 RR 4.4 HSE
2008 Audi A6
Post #70437 29th Jun 2011 5:22am
