![]() | Home > Wheels & Tyres > Ride making me queasy - is it the tyres? |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Maybe you're going through the change. |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
I found the Advans a bit squirmy and changed them for Pirelli Scorpions when they wore out. Felt much better afterwards d they don't do too bad off road either. FYI I have the same MY/spec as you. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
That very strange, try a couple of quells or stematil then give it a go.
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Ex leak into the vehicle maybe One day your life will flash before your eyes......................................make sure yours is worth watching!
xjsracer44 Member Since: 30 Nov 2010 Location: Hertfordshire Posts: 274 ![]() ![]() ![]() |
Was the car sitting around for a long time before you bought it, if so the tyres may have flat spotted and therefore cause a strange bobbing motion?
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
Before spending ANY money at all try the easiest check.
Check the pressures as advised above |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
First thing I'd do is look for exhaust leaks, or leaks from the breather pipes under the bonnet (at the back of the engine I think on yours). Carbon Monoxide - odourless and colourless - and can cause queasyness (before unconsciousness and death).
Harrup Member Since: 01 Jan 2013 Location: Devon Posts: 29 ![]() ![]() |
Firstly, sincere thanks to all for your input. Really appreciated.
CO2 detector...great catch, wish I had thought of that.
If you do get the tyres replaced and I still suspect they aren't the cause, ask to retain them as they could be used by another member, especially when they don't lead to the solution |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 640 ![]() ![]() ![]() |
My guess is that it'll be a CO problem and you're going to find that out prettty quick...
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
There are three standard sizes for the L322:
Across the L322 range of models and wheel sizes the outside rolling diameter of the standard supplied sizes were identical. This meant you could mix and match in an emergency.
