![]() | Home > Maintenance & Mods (L322) > Squeaky leather...... |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Hi
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
I had a similar problem with my drivers seat - it turns out that there is an edging trim that fits on the seat plastic where it rubs the leather - mine was missing it cost a few pence from a dealer and now no squeak. The silicon does work as does stuffing a j-cloth down there but in my case replacing the missing trim was the fix - now blissfully silent. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7994 ![]() ![]() ![]() |
I have this at the mo. From the drivers seat. I have the edging strip in place, as above, but the screw head has pulled through the plastic where the plastic side edge trim piece fastens on, so its moving about a bit, causing the noise...........
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
I was told that if you drive in just a G string smothered in baby oil this will feed the leather and stop any squeaks............................................................2 years later it still hasnt worked! One day your life will flash before your eyes......................................make sure yours is worth watching!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
To be honest, I've tried a few different leather cremes over the decades, and I'm back with good old Auto Glym.
Black leather, so god only knows how dirty it is. There is nothing that can't be fixed with a hammer😜😜
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Best solution I have found is to rub the edges of the plastic trim which touches the leather with candle wax, no more squeaks |
Any pics Johnny |
found the squeak, was the seatbelt reciever rubbing against the seat bolster/side, going to try and see what works...... There is nothing that can't be fixed with a hammer😜😜
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
I have had the same issue.
