![]() | Home > Maintenance & Mods (L322) > Egr valve, fix bumper and lost a spanner! |
I thought I'd lost one of my sockets in my Discovery engine bay, worried about it for about a day, then forgot. Six months later I was lying under the engine about to tighten up the exhaust downpipes ... guess what I found *STILL* attached .. yep, my socket! It hadn't fallen off the nut it was last used to tighten and gravity obviously mis-functioned |
OOh yes could be nasty if it came out on a Motorway.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35675 ![]() ![]() |
what Gary said or stick it in off road and crawl underneath...you should see it with a torch .. ... - .- -.
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 ![]() ![]() ![]() |
I put it in off road height and took the bolts out for the undertray but couldn't get it right off, I really haven't a clue where it is, I'm normally quite good at finding bits I drop as I'm a master at dropping stuff, iv used a torch but no joy, I'm worried it may cause some damage, iv checked around the belts and its not there and like you mention if it comes out at 70mph that won't be good, I'll have to take another look tomorrow |
Local roads & speedhumps may help! |
With regard to the egr.
An right thanks for that, think iv got bigger problems now though, just put a new post up about smoke coming from the filler cap so now I'm really worried the engines gone bad |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Sorry to hear about your engine issue.
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
I found a rusty spanner in my rear bumper a few weeks back. Was a nice snap-on one too ... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
I had a weird humm on my e39 bm, thought nothing too much of it, when i was checking something in the engine hole i found an 18" snap on pry bar, not mine. Bonus. There is nothing that can't be fixed with a hammer😜😜
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Spanner could have fallen into the viscous fan shroud, so nestling at the bottom of the radiator. The shroud not too difficult to loosen/release, but take care as the locating tabs will be quite brittle by now.
Good shout I'll have a look in the housing, it's had the newer vortex style filter fitted according to receipts but in going to take it off and check, just been to the local Indy who said it will be a ventilation issue and unlikely the engine is goosed, hope he is right, it's booked for the 25th to have the air suspension re calibrated anyway so he will take a look |
