![]() | Home > Technical (L322) > SOLVED - how to clear check brake pad message |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
Hi,
Must have a broken sensor wire or poor plug connector somewhere |
I hope not... I cannot be bothered fanny ballsing around getting behind the wheel arch liner to get a good look at the connection MY2010 TDV8 Vogue Ipanema Sand
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
If you go onto bimmernav it tells you on there |
Hi Andy, what's bimmer nav ? MY2010 TDV8 Vogue Ipanema Sand
http://www.bimmernav.com |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Something to put in the wiki? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35813 ![]() ![]() |
dumb question, but whats the bimmernav site got to do with the brake pad sensor problem.... ... - .- -.
You checked the front ones as well just incase? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Ain't checked the front one. Suppose I should , although front pads seem fine. Will update tonmorrow. MY2010 TDV8 Vogue Ipanema Sand
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Try ignition pos 2 for 30 seconds or until the warning liht goes out then ign off then start car .... Maybe an urban myth but a few BMW owners report that works for this issue.
i thought the light come after doing the rears... V8 facelift Range Rover Autobiography 22" wheels.
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
When I replaced my pads (all round with new sensors) the message went with no need to reset anything!
