![]() | Home > Technical (L322) > Trans Failsafe Mode Error |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
It's possible, but really only likely if you are moving from high to low / low to high ratios, which by the sound of it you aren't. It could be the transfer box itself, or worse ( |
| cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556
well i still get it into high and low, ive just took it round th eblock twice, its not until u go fromslow to fast or vice versa if that makes sense
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1042
My picture shows the rotary potentiometer for the transfer box shift motor. I don’t think that anything in your description particularly points to this being the issue in your case. The transmission P-codes are generally not emission related so a ‘universal’ diagnostic kit won’t decipher them correctly. You’re much better with some dedicated diagnostic kit like Testbook/T4.
Do u think im looking at a recon box phil? |
John came up with his snap on verdict today
If you use Manual mode to set off from rest and then, once you've done the 1-2 upshift, move the selector lever back to 'D' (without increasing the throttle enough to cause it to try to downshift into 1st again) does the transmission then behave correctly in fully automatic mode for the whole period before you next have to stop (or slow down enough to drop back into 1st gear again)?
Ill give that a try in tomorrow, I do believe it to be the first gear and I can see ur going in that route
To be honest I was more thinking that it would be best to rule out the 1st gear sprag unit first – especially as you mentioned a ‘slipping fan belt noise’ when you engaged ‘D’.
| JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833
Its like it has a high stall converter fitted, there is a big slip then it locks with a bang, on a simpler box I would describe it as low on fluid or blocked filter. One day your life will flash before your eyes......................................make sure yours is worth watching!
Okay, and does it pull away perfectly if Manual 1st is selected rather than 'D' or is the same problem there?
It's brilliant in manual 1st and 2nd 3rd etc
I've been told that the radiator can rust out causing water to get into the gearbox and cause these sort of symptoms is this true?? |
If that had happened the fluid would look like a pink cream. One day your life will flash before your eyes......................................make sure yours is worth watching!
Might b worth crawling underneath tomorrow and opening the fluid plug up and taking a peak |
| All times are GMT |
