Home > Technical (L322) > Trans Failsafe Mode Error
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Ive got a 4.4 v8 petrol with 65000 on the clock
Driving it tonight with no issues and parked up, went into a shop come out and put it in drive made a funny squeal like noise like a noises fan belt then up come Trans Failsafe mode.
I turned it off and back on and it was fine again for a while, i continued my journey and had to come to a stop to pull into a road the car made a clunk and up come Trans fail again
It runs reverse fine, it runs manual mode fine unless u go for kick down or let it act as a auto box.
Am i right in thinking it could be this part??
I saw this in Joes thread im hoping its this
Does anyone know what diagnostic kit would read the gear box fault correctly or is it a trip to the dealers??
Thanks
Neil
Post #163867 11th Jan 2013 9:09pm
It's possible, but really only likely if you are moving from high to low / low to high ratios, which by the sound of it you aren't. It could be the transfer box itself, or worse ( Crying or Very sad ) something in the gearbox.
RRPhil can more likely offer a better explanation of what might be the cause. .
Post #163911 12th Jan 2013 12:22am
cliffy
well i still get it into high and low, ive just took it round th eblock twice, its not until u go fromslow to fast or vice versa if that makes sense
Its like driving along and flooring it it over revs like a slip if that makes sense, but in manual mode its fine
Post #163913 12th Jan 2013 12:31am
RRPhil
My picture shows the rotary potentiometer for the transfer box shift motor. I don’t think that anything in your description particularly points to this being the issue in your case. The transmission P-codes are generally not emission related so a ‘universal’ diagnostic kit won’t decipher them correctly. You’re much better with some dedicated diagnostic kit like Testbook/T4.
Phil
Post #163914 12th Jan 2013 12:35am
cliffy
Do u think im looking at a recon box phil?
Post #163915 12th Jan 2013 12:49am
cliffy
John came up with his snap on verdict today
We got the the following codes off it
3B1h/15195 which said unknown
I also had
P0730 which said incorrect gear ratio
P0733 gear 3 incorrect gear ratio
P0732 Gear 2 incorrect ratio
In the transfer box
0x5212 batt under volt
0x52f2 instrument 3 lost from can
After the reset the gearbox showed P0730 again but nothing else
Any idea on this basis's guys
Post #164017 12th Jan 2013 3:45pm
RRPhil
If you use Manual mode to set off from rest and then, once you've done the 1-2 upshift, move the selector lever back to 'D' (without increasing the throttle enough to cause it to try to downshift into 1st again) does the transmission then behave correctly in fully automatic mode for the whole period before you next have to stop (or slow down enough to drop back into 1st gear again)?
You'll notice that I'm wondering if it's just 1st gear in automatic mode which is causing the problem.
Phil
Post #164146 13th Jan 2013 12:01am
cliffy
Ill give that a try in tomorrow, I do believe it to be the first gear and I can see ur going in that route
R u thinking its that seal??
Post #164150 13th Jan 2013 12:54am
RRPhil
To be honest I was more thinking that it would be best to rule out the 1st gear sprag unit first – especially as you mentioned a ‘slipping fan belt noise’ when you engaged ‘D’.
When 1st is selected in Manual mode it applies the F-brake, which bypasses the sprag.
If all gears work correctly in Manual mode then I think it’s unlikely to be the ‘standard’ 5HP24 bearing-then-seal failure. Selecting Manual mode would make no difference in that case.
Phil
Post #164272 13th Jan 2013 2:53pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Its like it has a high stall converter fitted, there is a big slip then it locks with a bang, on a simpler box I would describe it as low on fluid or blocked filter. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164276 13th Jan 2013 3:07pm
RRPhil
Okay, and does it pull away perfectly if Manual 1st is selected rather than 'D' or is the same problem there?
Phil
Post #164299 13th Jan 2013 3:53pm
cliffy
It's brilliant in manual 1st and 2nd 3rd etc
Auto it didn't play up till it was warm and now it's not giving the error just over rev'ing then catching the gear if that despription makes sense
When u put first put it in drive u feel it bit whilst holding the brake and then it re bites but harder feel like a double bite
I have noticed I can control the slip by backing of the accelerator
Post #164329 13th Jan 2013 4:48pm
cliffy
I've been told that the radiator can rust out causing water to get into the gearbox and cause these sort of symptoms is this true??
Post #164332 13th Jan 2013 4:56pm
JohnnyDangerous
If that had happened the fluid would look like a pink cream. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164345 13th Jan 2013 5:38pm
cliffy
Might b worth crawling underneath tomorrow and opening the fluid plug up and taking a peak
Post #164376 13th Jan 2013 6:59pm
