Home > Maintenance & Mods (L322) > Where to buy charging socket that goes in the tow socket
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Ive seen somewhere a charger socket that fit in the tow socket, it comes ready to plug into whatever charger you want, anyone have a link, I didnt save it. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164481 13th Jan 2013 11:31pm
BrianC
It's for sale in the fullfat shop right here !
Post #164482 13th Jan 2013 11:32pm
BrianC
http://www.disco3.co.uk/shop/index.php?act...oductId=45
Post #164483 13th Jan 2013 11:33pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
thanks for that. I'd been thinking about fabbing one but that has the charger connector and looks better Smile
Post #164516 14th Jan 2013 9:21am
5.0
Will this work on a MY 2010 with factory fit tow bar? I have a CTEK charger but it only seems to work if I attached it directly to the battery terminals. Using the interior power sockets does not work so will the tow bar socket be any different?
Post #165060 15th Jan 2013 9:06pm
As long as you have either a 12S socket (white) or a 13 pin socket it will work.
Both have a direct connection to the battery along with an earth connection.
The adaptors are configured to use these connections.
Post #165076 15th Jan 2013 10:07pm
supershuttle
All except the power socket in the boot are dead with the key out on mine, so I charge through the white plug just to make sure it starts on a cold morning, the advantage is that you can leave the car locked up and the bonnet closed. Disadvantage is my C-Tek doesn't charge the battery as fully as when directly connected under the bonnet so I do that occasionally - read never Laughing Geoff
Post #165126 16th Jan 2013 11:10am
STMVOGUE2010
I use an Optimate 4 advantage is this type of battery charger doesn't just charge battery it actively cycles battery which I think is better for battery in long run. Also comes with a dedicated connector that permanently fit to the car so you just plug in close bonnet and forget about it. They can be had for as little as £30 of fleabay worth it imho. Thumbs Up
Post #165156 16th Jan 2013 1:58pm
