![]() | Home > Maintenance & Mods (L322) > Where to buy charging socket that goes in the tow socket |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Ive seen somewhere a charger socket that fit in the tow socket, it comes ready to plug into whatever charger you want, anyone have a link, I didnt save it. One day your life will flash before your eyes......................................make sure yours is worth watching!
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
It's for sale in the fullfat shop right here ! |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
thanks for that. I'd been thinking about fabbing one but that has the charger connector and looks better |
As long as you have either a 12S socket (white) or a 13 pin socket it will work.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
All except the power socket in the boot are dead with the key out on mine, so I charge through the white plug just to make sure it starts on a cold morning, the advantage is that you can leave the car locked up and the bonnet closed. Disadvantage is my C-Tek doesn't charge the battery as fully as when directly connected under the bonnet so I do that occasionally - read never |
STMVOGUE2010 Member Since: 23 Aug 2012 Location: Alloa Posts: 100 ![]() ![]() |
I use an Optimate 4 advantage is this type of battery charger doesn't just charge battery it actively cycles battery which I think is better for battery in long run. Also comes with a dedicated connector that permanently fit to the car so you just plug in close bonnet and forget about it. They can be had for as little as £30 of fleabay worth it imho. |
