Home > Maintenance & Mods (L322) > dust shield or no dust shield?
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Dust shield on the front sides have disintegrated. Is it worthwhile replacing them or just leaving them off?
Thanks [/u] MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #165938 19th Jan 2013 7:25pm
Quote:
Dust shield
Question .
Post #165941 19th Jan 2013 7:48pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I reinforced the holes with "penny washers" and bolted them back up, I've had cars without them.
Post #165945 19th Jan 2013 8:11pm
woodchopper23
Good idea rich, I never thought of that. That's where mine have rusted through , at the bolt holes. MY2010 TDV8 Vogue Ipanema Sand
Post #165946 19th Jan 2013 8:14pm
woodchopper23
Sorry,
Dust sheilds around the brake discs MY2010 TDV8 Vogue Ipanema Sand
Post #165948 19th Jan 2013 8:17pm
Richcl
I guessed that is what you were on about, mine started clattering/rattling on every speedbump/pothole! Smile
Post #165949 19th Jan 2013 8:25pm
You have to remove the brake discs to fit new ones.
I'd be inclined to do the washer repair as above and replace the shields next time you replace the discs.
Post #165954 19th Jan 2013 8:54pm
You have to remove the hubs to replace them, unless you cut them off and cut through the new ones to refit!
I too, have used the washer repair to good effect. MOT man complains about these to me.... .
Post #165955 19th Jan 2013 9:00pm
I was told be an MOT tester you don't need the dust shields for an MOT.
Post #165956 19th Jan 2013 9:06pm
woodchopper23
Yes I would just cut them to fit them . But think ill see if I can undo the bolts and get some washers fitted to stop the clattering . MY2010 TDV8 Vogue Ipanema Sand
Post #165959 19th Jan 2013 9:22pm
daveo
i think you would find that they are only around £12 plus VAT for new ones £20 for the brembo ones, i cut my ones.. V8 facelift Range Rover Autobiography 22" wheels.
Post #165964 19th Jan 2013 9:50pm
