![]() | Home > Technical (L322) > Terrain response defaulting to Grass, Gravel, Snow?? |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Seems odd, mine always starts in Default even if I park the car with GGS set. |
If mine has been in GGS, and when I start it up it's around zero degrees or less it seems to go back to that setting. My 2010 would stay in whatever setting it was turned off in. Land Rover Addict
BuckinghamBazza Member Since: 18 Feb 2009 Location: Lancashire Posts: 23 ![]() |
The "Zero degrees" thing is interesting, that was one theory I had, but seems odd. |
Parked the car last night in GGS and this morning when I got in the car and it was -2 it was still in GGS. Does that help? |
It was -11 here ..... Land Rover Addict
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
i had this happen today also, but never done it before even when it's been very cold. usually no matter what it's set to, when you turn the car off it starts again with all special programs switched off.
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
I have this today. Admittedly it has been in GGS for the past 3 days - but I switched it off in town today and it was off when I switched off the car but when I got back in and started it it had defaulted to GGS. The temp was in the positives today as well.
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Mine is doing the same, |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2283 ![]() ![]() ![]() |
From memory so don't hold me to this I think it is a time thing must be in the manual somewhere but there is a way of cancelling it .
Yip. RTFM |
Other morning I switched off whilst in GGS and in less than 5mins came back and it had reset to normal. But a few times after that I've switched off in normal and it's gone back to GGS.
Yes, I thought I had cracked it but, |
This morning it said no program's and was in normal. Dropped child off and came back to car after 5mins and it was back in GGS. Came home this afternoon, no mention of special program's and was in normal and has been since. I've used the car about 6 times and no mention of special program's and been in normal every time. Touching wood again as I type. |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Had this the other day - managed to reset it by turning the ignition to position 2 (ie full elec but not starting the engine), waiting for the TR to show it was in the snow setting and then switching TR back to normal.
