Home > Maintenance & Mods (L322) > battery's
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
battery's
hi everyone, i have seen a few battery threads of late and i thought i saw one about have two batteries rigged up in the car, is this correct? as i understand its quiet common for 4x4's in the alps to have this?
andy
Post #166251 21st Jan 2013 1:18pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Here you go
http://www.rangerovers.net/rrupgrades/dualbattery.html
Post #166279 21st Jan 2013 2:55pm
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
has ne1 in the uk done this, i am willing to lots of money to have this done i have so much trouble with batteries in the rr
Post #166513 22nd Jan 2013 2:18pm
Yes 2 batteries in the l322 is easily possible as I'm sure dan_uk_1984 has done it. They aren't the same size but should provide enough juice to run the park heat and still start and having them both wrapped up in a blanket as will always help, look at vag and merc cars to see why.. You will only got something like an average family hatchback battery In the boot space anyway unless you cut some other bits out bit the bet thing to do if money is no object is replace the front battery with a 110ah Bosch s series from Ecp with a discount code and the same but smaller version for the boot as 2 new ones at the same time will be best. Be aware the one in the boot will my be able to start the l322 as the cabling isn't really rated to it.
Good luck Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #166523 22nd Jan 2013 2:58pm
And here is Dan_uk_1984's howto on a second battery
http://www.fullfatrr.com/forum/topic5721.html?
Can anyone give more info on the split charging setup? Dom? .
Post #166538 22nd Jan 2013 3:51pm
If you're putting a battery in the boot ( or anywhere inside the car) then make sure it is completely sealed as the fumes are toxic.
Whilst many these days claim to be sealed, that really just means maintenance free - I would only use something like an Optima which are sealed enough that they can be mounted any way you like, even upside down !
You can split charge in a number of different ways, but the main thing is to separate the batteries when not charging or they will drain each other. On my Jeep, I run 2 and just have a big relay powered by the ignition live. More sophisticated systems will charge just the starting battery until it is full before engaging the auxiliary.
On the FFRR, I've been happy enough with a single 110Ah Bosch
Post #166561 22nd Jan 2013 5:00pm
