![]() | Home > Maintenance & Mods (L322) > battery's |
| Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193
Here you go
| Polux Member Since: 02 Jun 2009 Location: UK Posts: 242
has ne1 in the uk done this, i am willing to lots of money to have this done i have so much trouble with batteries in the rr |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Yes 2 batteries in the l322 is easily possible as I'm sure dan_uk_1984 has done it. They aren't the same size but should provide enough juice to run the park heat and still start and having them both wrapped up in a blanket as will always help, look at vag and merc cars to see why.. You will only got something like an average family hatchback battery In the boot space anyway unless you cut some other bits out bit the bet thing to do if money is no object is replace the front battery with a 110ah Bosch s series from Ecp with a discount code and the same but smaller version for the boot as 2 new ones at the same time will be best. Be aware the one in the boot will my be able to start the l322 as the cabling isn't really rated to it.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6433
And here is Dan_uk_1984's howto on a second battery
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
If you're putting a battery in the boot ( or anywhere inside the car) then make sure it is completely sealed as the fumes are toxic.
