![]() | Home > Maintenance & Mods (L322) > battery's |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
Here you go
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
has ne1 in the uk done this, i am willing to lots of money to have this done i have so much trouble with batteries in the rr |
Yes 2 batteries in the l322 is easily possible as I'm sure dan_uk_1984 has done it. They aren't the same size but should provide enough juice to run the park heat and still start and having them both wrapped up in a blanket as will always help, look at vag and merc cars to see why.. You will only got something like an average family hatchback battery In the boot space anyway unless you cut some other bits out bit the bet thing to do if money is no object is replace the front battery with a 110ah Bosch s series from Ecp with a discount code and the same but smaller version for the boot as 2 new ones at the same time will be best. Be aware the one in the boot will my be able to start the l322 as the cabling isn't really rated to it.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
And here is Dan_uk_1984's howto on a second battery
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8061 ![]() ![]() ![]() |
If you're putting a battery in the boot ( or anywhere inside the car) then make sure it is completely sealed as the fumes are toxic.
