![]() | Home > Maintenance & Mods (L322) > Replacing sidelight bulbs with LED's |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
I did exactly the same today. best £5.99 spent ! i got my 4 year old to hold the bulbs so I didnt even need to disconnect the wires |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
Looks good |
before
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Damn it! The more I see you guys with the LED lights the more I want them, but I'm too lazy ... |
nine screws....15 mins max Alcohol and eBay is never a good mix
Yeah but once I get started I'll want to do the halogen fill-in lights and interior ... |
TASP I've bit the billet and ordered some |
Easy to do just ensure you put it in at 120 if using a fan oven for 8 mins. Make sure lught doesn't touch of sidof oven.put it on a pizza tray coverd in a tea towel. Make sure you remove all bulbs ad ballast before cooking Present :2008 TDV8 HSE
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
have done this too - looks awesome |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Worth noting that some LED bulbs only work if the polarity is the right way around, so before re-fitting the headlamps check both sidelights work... |
^ I did say that! Switch lights on to check bulbs work, if not turn them round! Previously..
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
Grand write up....may just have to do this myself...as you say the yellow incandescents look odd next to the whiter Xenons! |
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 ![]() ![]() ![]() |
Did it this morning, much better |
