![]() | Home > Maintenance & Mods (L322) > Main Beam LED's |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
I'm sure I;ve read this already but can;t find it in a search.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
you get an error cos the led bulb resistence is to low..you need to wire in a resister or another halogen bulb or get some h8 canbus error free leds.. ... - .- -.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Comports, surely they can't be very bright can they? An LED to replace a halogen...? |
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
You'd think that, but if you take a look at Audis with LED headlights they do a good job of dazzling the |
Yes but at 10x the cost of xenon headlamps i hardly see eBay bulbs will do the same job...... |
Hang on - Loads of folks have changed them over - It's only the Main (full beam) bulbs I'm talking about (I think).
you have bi-xenons which supply dip and main, the inner halogen mains are for show and 'flashing'...when i say for show i mean they only get 10volts and are useless against the xenon main...hope that makes sense.. ... - .- -.
It does - Thanks Stan..
check main beam 'could' be a problem with the bi-xenon but most likely the leds in the inner mains..
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964
Unless you use Navcoder to sort it out... |
