Home > Technical (L322) > TDV8 Turbo problems
Page 1 of 3 123>
JAYBOY
TDV8 Turbo problems
Hi all
Has anyone had any problems with Turbos on the TDV8 engine Question
I have had a few problems that i think i have sorted by Driving it like it was stolen.
I was out in the car on a long isn (around a racing track) journey.
When i reached 120mph the engine went into limp mode, so i took it easy after stopping and resarting the car which cleared the fault.
I took the car to my local indie and he reset the car, Took it out again and tried to replicate the fault and low and behold it happened again. So reset the car again. Anyway i went to Manchester today so on the way back i thought i would try again. So i popped to the (racing track again) to give the car some BEANS and it went all the way to the limiter and no fault.
I think i had a sticky waste gate and it was jamming open causing the fault. Has anyone else had the same problem.
I would have thought that David (dhallworth)drove the car very carefully and it never went over 100 mph so boost pressure would never have got to maximum boost.
Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #170072 4th Feb 2013 8:41pm
Could you not just have kept it in 3rd gear and floored it?? Revs would be the same and you are not driving at 120mph! Shocked Previously..
Post #170073 4th Feb 2013 8:47pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
More likely if its been pottered about the WG was not opening enough and it overboosted as the load increased and went into limp mode Thumbs Up One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #170075 4th Feb 2013 8:50pm
JAYBOY
No because it will automatically change up. I asked that to my indie.
He said it needs to be at full chat to have maximum boost or towing something heavy up hill a long hill to get the same pressure. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #170076 4th Feb 2013 8:50pm
JAYBOY
JohnnyDangerous wrote:
More likely if its been pottered about the WG was not opening enough and it over boosted
I think your right Johnny it needed a good clean out.
It seems to be perfect now. Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #170077 4th Feb 2013 8:52pm
JohnnyDangerous
The further up the box you go the more load you apply and the higher the boost it will try and hit which is ltd by the WG. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #170080 4th Feb 2013 9:00pm
Understood Thumbs Up Previously..
Post #170084 4th Feb 2013 9:06pm
JohnnyDangerous
Thats why the yoofs always end up blowing their cars up, they keep turning the boost up and get no DET in the lower gears, get em in 5th on a hill and they pink away and melt a piston Big Cry One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #170085 4th Feb 2013 9:09pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Scarey stuff on here sometimes:
120mph on presumed public roads.
Post #170092 4th Feb 2013 9:19pm
JAYBOY
120mph on presumed public roads is one thing
No on a track as said Thumbs Up
I was told by my indie the only way was at constant boost to make the WG work properly.
I have a good warranty as well Whistle 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #170096 4th Feb 2013 9:26pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
If you select the gear manually it should stay in that gear and not change up. you push the gear selector to the left to sport then forward for manual selection of the gears on mine. 04 td6. not sure bout the tdv8 but i would imagine it would be able to do this for off roading and heavy towing and the likes where you might want to hold it in a certain gear. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #170099 4th Feb 2013 9:30pm
JAYBOY
It automatically changes up on the revs. if you hit 4500 revs it changes up.Even in Manual 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #170106 4th Feb 2013 9:36pm
wats39
Must be a safety feature to protect the engine then which would make sense i suppose. aint had mines reving that high so maybe it does change up. will have to try the next time its out now Laughing '04 td6 se
Post #170121 4th Feb 2013 9:59pm
JAYBOY
wats39 wrote:
Must be a safety feature to protect the engine then which would make sense i suppose. aint had mines revving that high so maybe it does change up. will have to try the next time its out now Laughing
It shuts down to save the engine and turbo. Its quite common if the car is just poodles around.
give it a try Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #170123 4th Feb 2013 10:01pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
What's the redline on a TDV8 anyway (and what do they top out at)? Just hold it near without going over in 3rd? On my SC the redline varies depending on gearbox temps, which is a bit annoying :/
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #170141 4th Feb 2013 10:53pm
Page 1 of 3 123>
