![]() | Home > Technical (L322) > Problem with Mk4 Sat Nav |
| Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138
I thought it was just a case of popping the disc in and let it do its stuff
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
afaik, the mk4 reads dvd's not cd's.... ... - .- -.
| ksmith100 Member Since: 20 Apr 2012 Location: Stirling(ish) Posts: 77
It has been a while since i did one but that's how I remember it. Burn it on a good quality disc at as slow a speed as your burner will allow. It is possible you have a duff image. Also are you sure its a MKIV? I don't recall a MKIV with a monochrome screen, but I could be wrong. Check the model you have against the one shown here
Right it can be recoded but not with a simple cd:
Does anyone know what a GT-1 is? |
Yes, it is BMW diagnostic and coding software. I have it, but its a 30GB virtual machine. It is not straightforward to build one and you need all the software, plus the correct version. Also I dont believe it works with Range Rovers |
I'm started to wish I hadn't bought this bl__dy thing |
What car did it come out of? If you know someone with BMW that has sat nav using a MKIV you could recode it in that using GT1 |
Just for info, this is GT1
looks like the BMW equivalent to navcoder then... ... - .- -.
Navcoder is very limited in comparison, plus it needs a separate interface attached to the K bus to work DIS came first |
Thanks for the info
Still cheaper than a stealers for a new one |
Just to let you know its all working |
| All times are GMT |
