Home > Technical (L322) > Problem with Mk4 Sat Nav
Page 2 of 3 <123>
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I thought it was just a case of popping the disc in and let it do its stuff
I've downloaded the software from Matt Stevensons web site with the Landrover splash screen
on to a cd but the sat nav reads it then ejects it Evil or Very Mad
Post #171829 12th Feb 2013 8:35pm
afaik, the mk4 reads dvd's not cd's.... ... - .- -.
Post #171841 12th Feb 2013 9:03pm
ksmith100
Scotland 2005 Range Rover Vogue 4.4 V8 Java Black
It has been a while since i did one but that's how I remember it. Burn it on a good quality disc at as slow a speed as your burner will allow. It is possible you have a duff image. Also are you sure its a MKIV? I don't recall a MKIV with a monochrome screen, but I could be wrong. Check the model you have against the one shown here
http://www.google.co.uk/url?sa=t&rct=j...1806,d.d2k
Post #171842 12th Feb 2013 9:05pm
ksmith100
The update is still on a CD though, by design a DVD player, which is all these navigation computers are, will read a CD. The MKIV will happily read and use a any of the Navigation CD's from a MK1, MKII or MKII
Post #171845 12th Feb 2013 9:07pm
Tesh
Right it can be recoded but not with a simple cd:
First connect the GT-1
1. Code ZCS/FA
2. select after sales replacement(retrofit)( i know it isn't, but other wise you can't code the MK4
3. select IKE
4. select language
5. then you have to selet the 3 languages
6. Then on the nav screen you wil see load software. But you can’t see because your Nav still isn’t code for the Monitor. Butt you musst put the V26 in the MK4.
7. after you putt the V26 you have to wait in about 2 minutes the screen wil come, last time it took about 4 minutes.
8. After the succesfull software load , you have to select recode the Navigation computer, an you can code the MK4 to your car
Post #171853 12th Feb 2013 9:51pm
Tesh
Does anyone know what a GT-1 is?
Post #171856 12th Feb 2013 9:58pm
ksmith100
Yes, it is BMW diagnostic and coding software. I have it, but its a 30GB virtual machine. It is not straightforward to build one and you need all the software, plus the correct version. Also I dont believe it works with Range Rovers
Post #171864 12th Feb 2013 10:17pm
Tesh
I'm started to wish I hadn't bought this bl__dy thing
Post #171872 12th Feb 2013 10:43pm
ksmith100
What car did it come out of? If you know someone with BMW that has sat nav using a MKIV you could recode it in that using GT1
Post #171931 13th Feb 2013 11:05am
ksmith100
Just for info, this is GT1
Basically it is proprietary software that run on SCO Unix
Post #171938 13th Feb 2013 11:22am
looks like the BMW equivalent to navcoder then... ... - .- -.
Post #171942 13th Feb 2013 11:28am
ksmith100
Navcoder is very limited in comparison, plus it needs a separate interface attached to the K bus to work DIS came first
Post #171944 13th Feb 2013 11:38am
Tesh
Thanks for the info
Ive sent it to a guy in Birmingham to get it recoded at a cost of £125 inc 2012 disc and updated software and splash screen Big Cry Big Cry Big Cry
Post #171945 13th Feb 2013 11:39am
ksmith100
Still cheaper than a stealers for a new one
Post #171946 13th Feb 2013 11:40am
Tesh
Just to let you know its all working Very Happy
I sent it to a guy called NAVMAN in Birmingham he recoded it and cleaned the laser and sent it back the same day
What a difference the MK4 has made.
Its probably the best update Ive made since buying the car Thumbs Up
Post #172500 15th Feb 2013 5:13pm
Page 2 of 3 <123>
