Home > General > Wisdom comes with experience... and I'm short of both.
andyw wrote:
Quote:
got any tickets for the show? Thumbs Up
when is the next series on telly soon i hope Thumbs Up
AndyW........
Andy Wilman is the Exec Producer on Top Gear Laughing
Post #17239 22nd Apr 2010 8:03pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Obviously sick of sitting in the boot with the tailgate down Razz Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #17252 22nd Apr 2010 10:22pm
topgeartowers
I'm Rowland French Smile
Does anyone know how I can post a picture up here I took that I'd like have comments on from the engine bay of that car I was looking at?[/img]
Post #17275 23rd Apr 2010 10:58am
http://www.fullfatrr.com/forum/topic1022.html
http://www.fullfatrr.com/forum/topic1023.html
Post #17277 23rd Apr 2010 11:01am
topgeartowers
Thanks so much Mick - never would have worked that out without a prod in the right direction.
Please can anyone tell me if I should be worried/the cause of this oil leak around the right hand side (as you look at it from the front) of the engine.
Cheers in advance!
Rowly
Post #17278 23rd Apr 2010 11:23am
DMRR
Looks like the rocker cover gasket might need/already have been replacing/replaced, OR someone wasn't so careful when filling it with oil Whistle Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #17279 23rd Apr 2010 11:29am
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
About half way up the photo, you can see a little square cover. Pull this off and you get to a couple of bolts. Remove them and that whole cover comes off. (You need to take the main plastic cover off first though).
Under the RH cover, you will find the four plugs with their coil packs on top. See if there is any oil around the bottom of the plugs. If you are feeling adventurous, have a look under the other one too.
Oil around here only means the rocker gaskets need done... Not a big job, add it to the list though. Also look at the PCV hoses at the back.
DC
Post #17340 23rd Apr 2010 9:07pm
