![]() | Home > Technical (L322) > Urgent help needed - no electrics but battery not flat |
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 ![]() ![]() ![]() |
Hi all
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
it does sound like a flat battery...the fullfats ecu's talk to each other and if one particular ecu isnt getting its required voltage then it wont pass on any info to the next.....
+1 ^^^
Hi Stan
Battery on charge for over 30 hours and started no problem this morning. Did a 15 mile round trip, turned off engine, left it for an hour or so, back out to start it and........dead! Only 10.5v in the battery.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Assuming there are no issues with the alternator, could your battery have been killed by the recent cold weather?
As above my battery had been okay'ish up until the other night when i got out in the morning it was stone dead , had to get a new one as one of the cells were gubbed , and with it being -5 up here the other morning didn't help either … |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
Could be a dud battery. |
I've only had the vehicle 5 months and I had to buy a new battery within weeks of owning it! |
beg, borrow or buy a voltmeter/multimeter and check the idle voltage on the battery , should be 14.5 'ish volts, if not then its your alternator and if it is then its your battery..... ... - .- -.
Plus it could have been a Rogue battery you got , you do get them ….. |
Guess it could be the battery. But I've got it back on charge so I can start her up and check the charging rate. I've got a multi-meter, so no worries there.
Will do |
