![]() | Home > Technical (L322) > Urgent help needed - no electrics but battery not flat |
| dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242
Hi all
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
it does sound like a flat battery...the fullfats ecu's talk to each other and if one particular ecu isnt getting its required voltage then it wont pass on any info to the next.....
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
+1 ^^^
Hi Stan
Battery on charge for over 30 hours and started no problem this morning. Did a 15 mile round trip, turned off engine, left it for an hour or so, back out to start it and........dead! Only 10.5v in the battery.
| GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836
Assuming there are no issues with the alternator, could your battery have been killed by the recent cold weather?
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
As above my battery had been okay'ish up until the other night when i got out in the morning it was stone dead , had to get a new one as one of the cells were gubbed , and with it being -5 up here the other morning didn't help either … |
| Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156
Could be a dud battery. |
I've only had the vehicle 5 months and I had to buy a new battery within weeks of owning it! |
beg, borrow or buy a voltmeter/multimeter and check the idle voltage on the battery , should be 14.5 'ish volts, if not then its your alternator and if it is then its your battery..... ... - .- -.
Plus it could have been a Rogue battery you got , you do get them ….. |
Guess it could be the battery. But I've got it back on charge so I can start her up and check the charging rate. I've got a multi-meter, so no worries there.
Will do |
| All times are GMT |
