![]() | Home > Technical (L322) > TDV8 3.6 2007 - Intermittently Lumpy or WORSE. |
Sounds like you may have a few "old" fault codes there as well, so suggest to fully reset all the codes. Then see which codes come up after that, that are related to the engine management |
Porridge Member Since: 31 Mar 2011 Location: Dublin Posts: 51 ![]() ![]() ![]() |
Having done a bit of www trawling, I think the Dreaded LUC in the TC problem may be causing the "Cattle Grid" sensation.
Maybe your gearbox needs some TLC, oil and filter as well as a ECU update |
When the symptoms first started, the first thing I did was to get the Gearbox Oil and Filter changed. There is a bit of Authorative chat about this being a not-uncommon problem, though very mixed opinions as to the cause and the actual cure!
The good thing is, your gearbox is not the dreaded GL but the much hallowed ZF 6 speed and although the ZF is not perfect, they are pretty solid. I have been researching the gearbox extensively due to my 3-4 shift issue and more recent transmission cooler problem and I get a feeling that it is pretty damn good (unless it had a hard life).
Goodness me, I forgot one of the classics !!! The rear caliper problem !!! When it heats up, it starts binding and cause some (if not all) of the symptoms you are describing (I have had it on mine).
Brewster Member Since: 11 Sep 2012 Location: East Yorkshire Posts: 26 ![]() ![]() ![]() |
I've had both issues sir... independantly. I thought I was imagining things!! it was like a flat tyre or rumble strip but I was only doing 15mph I got out to check for a flat tyre but nothing was amiss , its never happened again.
BG244 Diesel Fuel System Cleaner |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
with the box being a 6 speed zf unit and not the 5 speed gm unit, as Ebajema has said it is a pretty robust unit. the GM box was made of chocolate and failed with regularity, was never really designed to be put in a 2.7t car maybe, but there seem to be few problems (ebajemas box rebuild excepted) with the zf. the hesitant shift from 1-2 is pretty common, and happens on quite a few cars. it can be improved with a software update, however it doesnt fully fix it. Mine does it on part throttle, but is smooth as a nut on full welly.
Stick in a tin of BG244 Diesel Fuel System Cleaner with 50/60 litres of quality diesel FIRST and run the car HARDish for at least 20-30 miles at least preferable more. The injector fault is/was there and the symptoms are similar to injector restriction. |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
I thought the TDV8 had the 8-speed box? Also don't throw water on your brakes, buy a cheap children's external thermometer (the type you put on your forehead) and use that on each WHEEL (not the disc rotor) after a run. It'll pick up the variation in wheel temps without the risk an tell you which wheel is binding.
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 ![]() ![]() ![]() |
Do not throw water on brakes ever, especially hot ones. That's a sure fire way to get a warped or cracked disc, not to mention the risk of steam burns!! Should've been old enough to know better...doh!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16343 ![]() ![]() ![]() |
The 3.6 gets the 6 speed and the 4.4 gets the 8 speed ![]() |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
What did this problem turn out to be? Mine has the same issue, it's currently at the mechanics and he hopes to know today. |
